CONNECT 100MBPS DEVICE TO 1GBPS SWITCH PORT CONGESTION
‎02-03-2021 01:21 PM
Hi Team,
Kindly suggest regarding following practical case If I connect a p.c/laptop with 10/100 lan card capacity to a 1 gbps port switch port congestion/packet drop might happen???
My switch is X440G2-48p-10G4
Thanks in advance
‎02-08-2021 09:08 PM
Roy,
I would put QoS in place to ensure that voip has priority over the PC.
Whatever the switch/port/settings, the PC will always be in competition with the Phone.
Mig
‎02-07-2021 06:05 AM
I was thinking if i can isolate those ip phones to a separate sub-vlan and reduce the port speed of the switch(will be shared to a 10/100 16 ports normal switch) to 100 mbps, as my switch is 10/100/1000, am i thinking in correct way?
means if i use this command
configure ports 1 auto on speed 100 duplex full
‎02-06-2021 05:37 PM
Roy,
main reasons for packet drops are
- wrong vlan configuration (dropping vlan packets not configured on both sides)
- wrong subnet configuration (too big subnet for the type of traffic)
- bandwidth congestion (QoS queuing incorrectly sized)
- cabling issue
- network attack or broadcast storm
A 100Mbps IP Phone with a PC connected on it will be very sensitive to all of this.
Mig
‎02-06-2021 05:09 PM
can u please brief possible reasons of packet drops apart from this speed mismatch. my environment is as follows.
single vlan in each switch with several sub-vlan+aruba wifi in network, with normal p.c+laptop in the end user, that’s it
and cables are are not faulty that’s i can say.
