enterasys C5G124 switch finding an IP on a port
caberot
I’m having trouble finding an IP address on a specific port for an enterasys C5G124 switch.
1 ACCEPTED SOLUTION
Tomasz
Valued Contributor II
How are you trying to find it? Using some SNMP manager to pull CtAlias MIB objects? That’s how it should be done on C5.
Kind regards,
Tomasz
1 REPLY 1
Tomasz
Kind regards,
Tomasz
