General Network Management
Questions and discussions about general network management practices
X460-48t - unable to type on PUTTY
I have a second hand Summit X460-48tI've tried using Linux / Windows, using several different cables, several different software packages (Tera Term, Putty, Screen)The furthest I ever seem to be able to get is where the switch is doing it's normal th...
lexifir by • New Contributor
  • 998 Views
  • 0 replies
Resolved! AP630 not booting - flashing white amber
Hi community,The AP is not booting. I think I need to connect via console, but from a mac I can't make it work. does anyone had a guite on how to connect to the device via console?or I can force reset it in any way?thank you
Configuração AP310e
Bom diaNão possuímos equipe qualificada para prestação de suporte técnico no Brasil, estou com dificuldades na criação de uma rede meshFoi disponibilizado arquivos não oficiais ensinando a configurar porem sem exitoGostaria de uma ajuda para configur...
