06-06-2022 09:43 AM
06-07-2022 12:54 PM
08-08-2022 07:39 AM
09-09-2022 02:48 PM
Hi
Really unlikely. You'd need 1024-QAM (WiFi6), 4x4 MIMO, wide channels, no interferences, small distance from AP to client, plus wifi client with same technical capabilities. So it is not what you usually can achieve in real deployment.
If you want to find out what is possible in theory check this one:
https://mcsindex.com/
Keep in mind that theese are theoretical connection rates, not real throughput. Real throughput with a half of wifi connection rate can be considered as normal.
Adam
