Real world expected wifi connection speed
EwanC
Hi, we have recently installed 305c Ap's and 410 Ap's across our entire estate.  Has anyone got some kind of knowledge about what kinds of connection speeds/ bandwidth clients should expect when connected via modern windows 10 laptop?
At the moment the bandwidth available compared to a wired connection seems very low. Even when my laptop is the only device on wifi.
For example on Wired I get this from my laptop to a wired server with gbit ports using iperf.
iperf>iperf3 -c w.x.y.z
Connecting to host w.x.y.z, port 5201
[ 4] local A.B.C.D port 1602 connected to w.x.y.z port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 78.9 MBytes 661 Mbits/sec
[ 4] 1.00-2.00 sec 80.5 MBytes 676 Mbits/sec
On wireless I get this
C:\iperf>iperf3 -c w.x.y.z
[ 4] local A.B.C.D port 28936 connected to w.x.y.z port 5201
[ 4] 0.00-1.00 sec 11.3 MBytes 94.9 Mbits/sec
[ 4] 1.00-2.00 sec 10.8 MBytes 90.3 Mbits/sec
Is this typical ?
Thanks,
Ewan
3 REPLIES 3
SamPirok
Community Manager
Hi Ewan, with wireless speeds you're going to have to expect to only get about half of what you get with wired, and that's a best case scenario. After that there are several environmental factors that can have a negative impact on your wireless speeds. In general you'll want to look in to Radio Frequency Interference, and try to avoid any metal, glass, or water in the area you want your wireless signal to be. If you think of wireless signal like a sound wave, any obstacles in between where the signal is coming from and where the signal is going will impede your signal somewhat. Metal, glass, water and by extension large amounts of people (since we're basically water to a wireless signal) will all damage (i.e. reflect, refract, generally fragment) the signal more than other obstructions. Also, the more wireless signal in one area, the worse your signal will be, so limiting the number of overlapping wireless signals in your network space will help with interference as well. Hope this helps!
Can I get 1000 Mbps over WiFi?  DinarRecaps.com
Hi
Really unlikely.  You'd need 1024-QAM (WiFi6), 4x4 MIMO, wide channels, no interferences, small distance from AP to client, plus wifi client with same technical capabilities. So it is not what you usually can achieve in real deployment.
If you want to find out what is possible in theory check this one:
https://mcsindex.com/
Keep in mind that theese are theoretical connection rates, not real throughput. Real throughput with a half of wifi connection rate can be considered as normal.
Adam
