Whole switch ports mirror for Enterasys family
Amr
The question dedicated for A4,B5,C5 and I series, could we able to mirror the whole ports or VLANs of that switches to one port?
ie→ need to create SPAN port on each type to mirror the traffic inside the switch “VLANS, ports”
3 REPLIES 3
Amr
Thanks @StephanH,
How to do this with Enterasys switches? and to proceed if we need to be used with IDS (Intrusion Detection System)?
StephanH
Valued Contributor III
This is one of the reasons why Extreme uses techniques like CoreFlow or special policies for analytics in order not to have to read the entire traffic.
Regards Stephan
StephanH
Hello Amr,
no, when you mirror all ports to one,then this port is flooded with more data than it can handle. As an example, 10x 1G on a 1G port cannot work.
Regards Stephan
