Not able to check reference firmware for X435
JohanHendrikx
Contributor II
I’am not able to select a reference firmware for the X435 switch.
For X440-G2, X450-G2 it is possible to do that
Johan Hendrik System Architect Audax
1 ACCEPTED SOLUTION
JohanHendrikx
Contributor II
Miguel-Angel,
I thought I uploaded the correct firmware  c42bf58360c1409da3e01d0a1a04dc53_1f610.png.
Now I can select the x435.
Thanks
2 REPLIES 2
JohanHendrikx
Contributor II
Miguel-Angel,
Thanks
Miguel-Angel_RO
Valued Contributor II
Johan,
If I remember well, the X435 is using another binary file (arm CPU).
Did you uploaded the specific firmware for this family?
Mig
