XIQ Site Engine and XIQ On-Premise
s_vey
New Contributor II
Hi everybody,
is it possible to connect the XIQ-SE to an on-premise XIQ Installation?
regards
2 REPLIES 2
Zdeněk_Pala
Valued Contributor III
Hi s.vey.
The ExtremeCloud IQ - Site Engine is compatible with Distributed Cloud Platform. Distributed Cloud Platform is ExtremeCloud IQ installed in the customer/partner premises and operated by Extreme's DevOps.
The ExtremeCloud IQ - Site Engine is not compatible with IQVA. IQVA is derived from ExtremeCloud IQ, it is installed in the customer/partner premises and operated by the customer/partner.
IQVA and Distributed Cloud Platform are different products.
Thanks
Zdenek
Regards Zdeněk Pala
Ryan_Yacobucci
I don't believe this is supported. I am checking with PLM.
Thanks
-Ryan
