‎08-02-2017 11:17 AM
At the beginning it was a problem with my switch Fans
then Then the switch turned off
and i can't have an acces to my switch
i tried to booting the switch with this soltion
https://extremeportal.force.com/ExtrArticleDetail?an=000074969
but without result
If I try to install EXOS (summitX-15.3.3.5.xos) from bootrom it failed with the following error :
download: The image you attempted to load is either not a recovery image or it may be corrupted. Please try again.
‎08-02-2017 12:37 PM
This is probably a hardware failure. I'd recommend opening up an RMA with GTAC.
