Extreme Switch x650 get stuck after show config command
Pao_Morales
Hello All,
After I issued : show configuration command, the switch does not dispay anything, I press enter many times and just the promt go down , but nothing happens.
Should I reload the switch?
This switch is in a stack  is no the master.
Thanks a lot!!
6 REPLIES 6
Eric_Burke
New Contributor III
Any luck Pao?
Eric_Burke
New Contributor III
If you're in SSH, this may be a reported bug in an older version of code that I've run into. If you reboot the switch, but might come back again. Newer firmware seemed to address it. Has something to do with a change in the 3rd party SSH module they were using. Not 100%, but give it a shot.
