‎05-20-2021 07:45 PM
We have our own fiber mesh and SPBM running fine. We are getting additional links at multiple sites from an ISP. The ISP is using q-in-q so we basically have a pseudowire from the core to each site. Since we cannot map our 2 BVLANs to multiple ISP tags we need to use layer 3 fabric extend, as far as I understand. It seems like this is possible, but I haven’t been able to locate a good example yet. Am I thinking about this wrong? Would this require our interface to the ISP at both ends to be a layer 3, routed interface? Would we need a separate /30 between the core and each site? I’m sure I have more questions, but this would be a good start.
Solved! Go to Solution.
‎05-23-2021 01:06 PM
‎06-04-2021 12:50 PM
Just wanted to share an update on this. We decided we didn’t want to use the 2 additional VLANs needed per site to map the BVLANs so I changed our uplink to the provider to a layer 3 interface. This allows us to route across the provider. Then set a loopback as a source IP. Create a logical interface that points to the remote loopback. You have to do this for each site, but can have multiple tunnels extending the fabric. Here is my configuration steps, test configs & some verification.
!!! CONFIGURATION STEPS !!!
1. Set the prompt to help ID switches when in the CLI
prompt "SWITCH-NAME"
3. Configure loopback IP to be used as source/destination.
interface loopback <1-256>
ip address <IP/32>
exit
2. Configure basic ISIS & SPBM parameters.
spbm
router isis
sys-name SWITCH-NAME
system-id <ID>
manual-area 49.0001
spbm 1
spbm 1 nick-name <NICK-NAME>
spbm 1 b-vid 4051-4052 primary 4051
ip-tunnel-source-address <LOOPBACK-IP>
y
exit
vlan create 4051 name PBVID type spbm-bvlan
vlan create 4052 name SBVID type spbm-bvlan
router isis enable
3. Remove physical port from other vlans.
vlan members remove 1 1/24
4. Change physical port to routed port. Using VLAN 3000 as an example.
This VLAN is not a regular port VLAN. If you try to "create vlan 3000"
you'll get an error message.
interface g 1/24
brouter port 1/24 vlan 3000 subnet <INTERFACE-IP>/255.255.255.0
name "ISP-UPLINK"
no shut
exit
5. Configure logical interface with remote loopback as destination. A
logical interface will need to be configured per adjacency.
logical-intf isis 1 dest-ip <REMOTE-LOOPBACK> name <REMOTE-SWITCH-NAME>
isis
isis spbm 1
isis enable
exit
6. Create static route to remote loopback via layer 3 interface. Could use
OSPF to advertise the loopback IPs instead of a bunch of static routes.
ip route <REMOTE-LOOPBACK> 255.255.255.255 <REMOTE-ROUTED-INTERFACE-IP> weight 1
ip route <REMOTE-LOOPBACK> 255.255.255.255 <REMOTE-ROUTED-INTERFACE-IP> enable
7. Create test VLAN to see if MAC data is learned on remote switch
vlan create 99 name DATA type port-mstprstp 0
vlan i-sid 99 100099
vlan members add 99 1/2
interface g 1/2
no shut
exit
!!! SWITCH CONFIGURATIONS !!!
Test switch 1
prompt "TEST1"
interface loopback 100
ip address 10.0.100.1/32
exit
spbm
router isis
sys-name TEST1
system-id 0001.5000.0500
manual-area 49.0001
spbm 1
spbm 1 nick-name 1.50.05
ip-tunnel-source-address 10.0.100.1
y
exit
router isis enable
interface g 1/24
brouter port 1/24 vlan 3000 subnet 10.30.30.1/255.255.255.0
no shut
exit
logical-intf isis 1 dest-ip 10.0.100.2 name TEST2
isis
isis spbm 1
isis enable
exit
logical-intf isis 2 dest-ip 10.0.100.3 name TEST3
isis
isis spbm 1
isis enable
exit
ip route 10.0.100.2 255.255.255.255 10.30.30.2 weight 1
ip route 10.0.100.2 255.255.255.255 10.30.30.2 enable
ip route 10.0.100.3 255.255.255.255 10.30.30.3 weight 1
ip route 10.0.100.3 255.255.255.255 10.30.30.3 enable
interface g 1/2
no shut
exit
!!!CONNECT LINKRUNNER TO PORT 1/2 AND TURN ON
Test switch 2
prompt "TEST2"
ip address 10.0.100.2/32
exit
spbm
router isis
sys-name TEST2
system-id 0001.5000.0600
manual-area 49.0001
spbm 1
spbm 1 nick-name 1.50.06
ip-tunnel-source-address 10.0.100.2
y
exit
router isis enable
interface g 1/24
brouter port 1/24 vlan 3000 subnet 10.30.30.2/255.255.255.0
no shut
exit
logical-intf isis 1 dest-ip 10.0.100.1 name TEST1
isis
isis spbm 1
isis enable
exit
isis
isis spbm 1
isis enable
exit
ip route 10.0.100.1 255.255.255.255 10.30.30.1 weight 1
ip route 10.0.100.1 255.255.255.255 10.30.30.1 enable
Test switch 3
prompt "TEST3"
ip address 10.0.100.3/32
exit
spbm
router isis
sys-name TEST1
system-id 0001.5000.0700
manual-area 49.0001
spbm 1
spbm 1 nick-name 1.50.07
ip-tunnel-source-address 10.0.100.3
y
exit
router isis enable
interface g 1/24
brouter port 1/24 vlan 3000 subnet 10.30.30.3/255.255.255.0
no shut
exit
isis
isis spbm 1
isis enable
exit
logical-intf isis 2 dest-ip 10.0.100.2 name TEST2
isis
isis spbm 1
isis enable
exit
!!! VERIFY ADJACENCIES & MAC LEARNING !!!
On switch TEST1, verify ISIS adjacencies. Then connect link runner to access
port 1/2 in vlan 99 (i-sid 100099).
TEST1:1#sh isis adj
Command Execution Time: Thu Jun 03 19:50:47 2021 UTC
ISIS Adjacencies
INTERFACE L STATE UPTIME PRI HOLDTIME SYSID HOST-NAME STATUS
TEST2 1 UP 00:38:36 127 22 0001.5000.0600 TEST2 ACTIVE
TEST3 1 UP 00:24:59 127 20 0001.5000.0700 TEST3 ACTIVE
2 out of 2 interfaces have formed an adjacency
TEST1:1#
TEST1:1#show vlan mac-address-entry port 1/2
Command Execution Time: Thu Jun 03 19:52:10 2021 UTC
Vlan Fdb
VLAN MAC SMLT
ID STATUS ADDRESS INTERFACE REMOTE TUNNEL
99 learned 00:c0:17:b7:90:d2 Port-1/2 false -
c: customer vid u: untagged-traffic
1 out of 17 entries in all fdb(s) displayed.
TEST1:1#
On switch TEST2, verify adjacencies and remote MAC learning.
TEST2:1#sh isis adj
Command Execution Time: Thu Jun 03 19:54:07 2021 UTC
ISIS Adjacencies
TEST1 1 UP 00:40:59 127 19 0001.5000.0500 TEST1 ACTIVE
TEST3 1 UP 00:12:30 127 22 0001.5000.0700 TEST3 ACTIVE
TEST2:1#sh vlan mac-address-entry
Command Execution Time: Thu Jun 03 19:54:57 2021 UTC
Vlan Fdb
VLAN MAC SMLT
99 learned 00:c0:17:b7:90:d2 TEST1 false TEST1
On switch TEST3, verify adjacencies and remote MAC learning.
TEST3:1#sh isis adj
Command Execution Time: Thu Jun 03 19:58:22 2021 UTC
ISIS Adjacencies
TEST1 1 UP 00:28:58 127 24 0001.5000.0500 TEST1 ACTIVE
TEST2 1 UP 00:14:07 127 23 0001.5000.0600 TEST2 ACTIVE
TEST3:1#sh vlan mac-address-entry
Command Execution Time: Thu Jun 03 19:58:27 2021 UTC
Vlan Fdb
VLAN MAC SMLT
‎05-25-2021 06:59 PM
Well, looks like it won’t work. At least I know and can plan accordingly!
‎05-25-2021 02:12 PM
bfaltys,
I don’t think so but I can’t confirm.
I’m pretty sure you can add this to an existing dot1q interface without any issue.
You can easily test it on an unused interface. Tagg it and add a logical interface
Mig
‎05-25-2021 02:09 PM
If I add this to use a physical port that is already operating as an 802.1q trunk will it break the trunking? If it will I will have to configure a new interface and then move the link to the new one once everything is ready.
