Fabric Extend over ISP (Hub-and-spoke)
bfaltys
Contributor II
We have our own fiber mesh and SPBM running fine. We are getting additional links at multiple sites from an ISP. The ISP is using q-in-q so we basically have a pseudowire from the core to each site. Since we cannot map our 2 BVLANs to multiple ISP tags we need to use layer 3 fabric extend, as far as I understand. It seems like this is possible, but I haven’t been able to locate a good example yet. Am I thinking about this wrong? Would this require our interface to the ISP at both ends to be a layer 3, routed interface? Would we need a separate /30 between the core and each site? I’m sure I have more questions, but this would be a good start.
1 ACCEPTED SOLUTION
Miguel-Angel_RO
Valued Contributor II
Hi bfaltys,
L3 interfaces are not needed.
Here from the doc:
Mig
13 REPLIES 13
Miguel-Angel_RO
bfaltys
Contributor II
I didn’t have the i-sids configured. Doh! Looks like it is working!
bfaltys
Contributor II
Thanks. I will look through that to see if/what I’m missing. I currently have an adjacency, but not seeing any MACs learned from the other switch.
TEST1:1#sh isis adj
                Command Execution Time: Tue May 25 13:48:12 2021 UTC
                                ISIS Adjacencies
INTERFACE         L STATE        UPTIME PRI HOLDTIME SYSID             HOST-NAME         STATUS
2258-1/24         1 UP         00:12:08 127       27 0001.5000.0600    TEST2             ACTIVE
 1 out of 1 interfaces have formed an adjacency
TEST1:1#sh vlan mac
TEST1:1#sh vlan mac-address-e
TEST1:1#sh vlan mac-address-entry
                Command Execution Time: Tue May 25 13:48:18 2021 UTC
                                    Vlan Fdb
VLAN            MAC                                   SMLT
ID   STATUS     ADDRESS            INTERFACE          REMOTE   TUNNEL
10   learned    00:e0:4c:68:35:01  Port-1/14          false    -
10   self       f0:64:26:68:d9:00  Port-cpp           false    -
4051 self       00:01:50:00:05:00  Port-cpp           false    -
4051 self       00:01:50:00:06:00  2258-1/24          false    -
4051 self       12:50:05:ff:ff:ff  Port-cpp           false    -
4051 self       12:50:06:ff:ff:ff  2258-1/24          false    -
4052 self       00:01:50:00:05:00  Port-cpp           false    -
4052 self       00:01:50:00:06:00  2258-1/24          false    -
4052 self       12:50:05:ff:ff:ff  Port-cpp           false    -
4052 self       12:50:06:ff:ff:ff  2258-1/24          false    -
c: customer vid   u: untagged-traffic
10 out of 10 entries in all fdb(s) displayed.
TEST1:1#
bfaltys
Contributor II
Do you have a link to the guide you referenced? I’d like to look at that if it contains an example. I think I’m tracking on what to do, but a guide would be helpful just in case.
