Hi Mikhail,
For Avaya branded firmware versions you don't need to worry about Avaya VSAs. For Nortel branded firmware versions it's/was more "complicated", different to configure.
In your case, just add the following line to the RADIUS Return Attributes for your Avaya
switch(es) in NAC Manager -> Switches Tab -> Edit Switch -> RADIUS Return Attributes, select
the one you are currently using:
Service-Type=%Custom1% (or %Custom2%...%Custom5%)
In the NAC Profile which is used/applied for CLI access, just use the following values in
the Custom1 to Custom5 fields, whichever you used in the above defined RADIUS Return Attribute:
A value of "6" gives you admin/RW privileges in the CLI (telnet/SSH).
A value of "7" gives you read-only privileges.
That's it basically and has worked so far for any Avaya switches.
Hope this helps.
Kind regards,
Markus
