OneView maps building links between non Extreme devices
‎12-09-2015 07:40 PM
Is it possible to have OneView build links between non Extreme devices? I have a bunch of Transition Networks switches in my network and I would like to populate the links between them. OneView builds the link from the Extreme switch to the first Transition switch but won't build the links after that.
Thanks !
Thanks !
11 REPLIES 11
‎12-10-2015 02:36 PM
Yes, LLDP is enabled. The Extreme switches show the LLDP neighbor information for the Transition switch directly attached to it and the Transition switches show the the neighbor information between themselves. I also enabled SNMP Traps to the NetSight server but the links are still not populating. How would I go about checking the MIBs?
Thanks for the help!
‎12-10-2015 07:35 AM
Did you ensure that LLDP is enabled and running correctly on those switches? have you configured SNMP traps? Oneview pulls information from the LLDP MIB tables and from LLDP traps. You are probably getting the link from the Extreme switch because we get the information from that and can draw one link, but since the other devices either are not sending/do not have the right MIBs, we cannot pull that information and draw additional links.
