Problem with Enterasys B5G124 and D2G124 VLAN connection
Piotr
Hello friends,
I have a huge problem with my VLAN connection. I've network in 2 locations:
Location 1 - central building with B5G124 router (IP 192.168.20.250) and computer (IP 192.168.30.200)
Location 2 - other building: an IP camera (IP 192.168.103.71) and computer (IP 192.168.103.200) connected to D2G124 switch (IP 192.168.20.251).
Connection between router (ge.1.23) and switch (ge.1.12): fiber optic
I can pinging between router and switch. I haven't any pings between computer in location 1 and camera, computer in location 2. Where is problem?
PS. Forgive me friends - I'm not IT specialist - I'm only engineer in energetic speciality.
Config of switches and VLAN was listed below:
LOCATION 1
VLAN: 1 NAME: DEFAULT VLAN
VLAN Type: Default
Egress Ports
None.
Forbidden Egress Ports
None.
Untagged ports
None.
VLAN: 20 NAME: Management
VLAN Type: Permanent
Egress Ports
ge.1.5, ge.1.23-24
None.
Untagged ports
ge.1.5
VLAN: 30 NAME: WORK
Egress Ports
ge.1.1-3, ge.1.23-24
None.
Untagged ports
ge.1.1-3
VLAN: 103 NAME: CAMERAS
Egress Ports
ge.1.23
None.
Untagged ports
None.
LOCATION 2
VLAN Type: Default
Egress Ports
ge.1.12
None.
Untagged ports
ge.1.12
Egress Ports
ge.1.12
None.
Untagged ports
None.
VLAN: 30 NAME: WORK
Egress Ports
ge.1.12
None.
Untagged ports
None.
Egress Ports
ge.1.1, ge.1.12
None.
Untagged ports
ge.1.1
Configuration of router
#vlan
set vlan create 20
set vlan create 30
set vlan create 103
set vlan name 20 "Management"
set vlan name 30 "WORK"
clear vlan egress 1 ge.1.1-5;ge.1.13;ge.1.19-24
set vlan egress 20 ge.1.23-24 tagged
set vlan egress 20 ge.1.5 untagged
set vlan egress 30 ge.1.23-24 tagged
set vlan egress 30 ge.1.1-4 untagged
set vlan egress 103 ge.1.13;ge.1.23 tagged
set host vlan 20
#Router Configuration
interface vlan 20
exit
interface vlan 30
ip address 192.168.30.254 255.255.255.0
no shutdown
exit
interface vlan 103
ip address 192.168.103.252 255.255.255.0
no shutdown
#port
set port vlan ge.1.1 30
set port vlan ge.1.2 30
set port vlan ge.1.5 20
set port vlan ge.1.12 20
set port vlan ge.1.13 103
set port vlan ge.1.23 30
set port vlan ge.1.24 30
Configuration of switch:
#vlan
set vlan create 20
set vlan create 30
clear vlan egress 1 ge.1.1;ge.1.11
set vlan egress 20 ge.1.11-12 tagged
set vlan egress 30 ge.1.11-12 tagged
set vlan egress 30 ge.1.1-2 untagged
set host vlan 20
#port
set port disable ge.1.2
set port disable ge.1.3
set port disable ge.1.4
set port disable ge.1.5
set port disable ge.1.6
set port disable ge.1.7
set port disable ge.1.8
set port disable ge.1.9
set port disable ge.1.10
set port disable ge.1.11
set port duplex ge.1.1 full
set port speed ge.1.1 1000
I'm still self learning abou IT, but this is really wide range of science. I would be grateful for any help!
Peter
11 REPLIES 11
Piotr
Thanks Christoph! You have right of course! I missed my last configuration file (of switch) and pasted wrong (earlier) version. Here is good (directly from device):
#vlan
set vlan create 20
set vlan create 30
set vlan create 103
set vlan name 30 WORK
set vlan name 103 "CAMERAS"
set vlan egress 30 ge.1.2 untagged
set vlan egress 103 ge.1.11-12 tagged
set vlan egress 103 ge.1.1 untagged
set host vlan 20
#port
set port vlan ge.1.1 103
With configuration as above connection not working. I'm sorry for mistake!
Christoph
Contributor
you missed to configure vlan 103 on switch in location 2
