Problem With Port QSFP+ 40G to 4x10G
nahum
hello
I have the following situation:
I have a Switch summit x670. I have configured 2-port QSFP + as 4x10G each, in which I am connecting a cable with MPO connector to 6 lc connectors.
The problem is that when I connect the cable, I have no link nor in the QSFP + port, nor in SFP + ports.
I have configured the ports to 10000 speed, full duplex, auto off. I have also assigned four vlans tag and untag one in each port 10g.
I appreciate the support.
Sorry for my bad English.
regards
5 REPLIES 5
Ron_Huygens
Community Manager
Hi Nahum,
I think that is the right cable. It does look similar to the one I have.
All connectors seems the right type as well as the fiber type.
For proper clarification, you can contact your local SE.
Thanks,
Ron
nahum
Hi Ron
Thanks for responding
You could confirm if it works with the following breakout?
40 Gigabit Ethernet QSFP 40GBase-SR4 to MTP(MPO)/LC (4 Duplex LC) 1/2 Meter Breakout Cable, OM3, 50/125, 3 meter.
  • Connector A) MTP/MPOfemale
  • Connector ļ˜Ž LC/UPC
  • 40Gb pin-out configuration
  • Jacket Type: Plenum Rated (OFNP)
  • Jacket Color: Aqua (blue)
  • Fiber Mode: Multimode 50 Laser Optimized OM3
  • Breakout Length: 1/2 Meter (~24 Inches)
  • Cable type: Corning 3mm round to 2mm on the breakout side
  • Fiber Count: 8 Fibers
http://fibertronics-store.com/images/1368879979067-1241365508.png
Thanks for the support
Regards
Ron_Huygens
Community Manager
Hi Nahum,
Unfortunately it is not possible to use this type of cable. The QSFP in 4 x 10gig mode will only support a breakout cable with 4 lc connectors.
Thanks,
Ron
nahum
hi Ron
My cable is 6 lc connectors. I suppose that's the problem. You think I can run with this cable?
http://www.panduit.com/heiler/ProductImages/BHYDRA10GQN-o.jpg
Because already purchased.
Thanks for the answer.
regards
