Problem With Port QSFP+ 40G to 4x10G
‎02-26-2014 07:00 PM
hello
I have the following situation:
I have a Switch summit x670. I have configured 2-port QSFP + as 4x10G each, in which I am connecting a cable with MPO connector to 6 lc connectors.
The problem is that when I connect the cable, I have no link nor in the QSFP + port, nor in SFP + ports.
I have configured the ports to 10000 speed, full duplex, auto off. I have also assigned four vlans tag and untag one in each port 10g.
I appreciate the support.
Sorry for my bad English.
regards
regards
5 REPLIES 5
‎02-28-2014 08:16 AM
Hi Nahum,
I think that is the right cable. It does look similar to the one I have.
All connectors seems the right type as well as the fiber type.
For proper clarification, you can contact your local SE.
Thanks,
Ron
Thanks,
Ron
‎02-27-2014 03:45 PM
Hi Ron
Thanks for responding
You could confirm if it works with the following breakout?
40 Gigabit Ethernet QSFP 40GBase-SR4 to MTP(MPO)/LC (4 Duplex LC) 1/2 Meter Breakout Cable, OM3, 50/125, 3 meter.
Thanks for the support
Regards
- Connector A) MTP/MPOfemale
- Connector  LC/UPC
- 40Gb pin-out configuration
- Jacket Type: Plenum Rated (OFNP)
- Jacket Color: Aqua (blue)
- Fiber Mode: Multimode 50 Laser Optimized OM3
- Breakout Length: 1/2 Meter (~24 Inches)
- Cable type: Corning 3mm round to 2mm on the breakout side
- Fiber Count: 8 Fibers
Regards
‎02-27-2014 06:56 AM
Hi Nahum,
Unfortunately it is not possible to use this type of cable. The QSFP in 4 x 10gig mode will only support a breakout cable with 4 lc connectors.
Thanks,
Ron
Thanks,
Ron
‎02-26-2014 10:06 PM
hi Ron
My cable is 6 lc connectors. I suppose that's the problem. You think I can run with this cable?
http://www.panduit.com/heiler/ProductImages/BHYDRA10GQN-o.jpg
Because already purchased.
Thanks for the answer.
regards
regards
