Why does flow-redirect not work?
‎01-27-2016 07:07 PM
configure
snmp sysName "LAYER2-3_SWITCH"
configure sys-recovery-level switch reset
configure vlan default delete ports all
configure vr VR-Default delete ports 1-5
configure vlan default delete ports 1-5
configure vlan "Default" qosprofile QP1
create vlan "GW_primary"
configure vlan GW_primary tag 10
create vlan "GW_secondary"
configure vlan GW_secondary tag 20
create vlan "Network"
configure vlan Network tag 30
configure vlan GW_primary add ports 1 untagged
configure vlan GW_secondary add ports 2 untagged
configure vlan Network add ports 3 untagged
configure vlan GW_primary ipaddress 192.168.8.36 255.255.255.0
enable ipforwarding vlan GW_primary
configure vlan GW_secondary ipaddress 192.168.11.254 255.255.255.0
enable ipforwarding vlan GW_secondary
configure vlan Network ipaddress 10.0.0.1 255.255.255.0
enable ipforwarding vlan Network
configure iproute add 192.168.12.0 255.255.252.0 192.168.11.253
configure ipforwarding originated-packets require-ipforwarding
create flow-redirect primary_GW
configure flow-redirect primary_GW add nexthop 192.168.8.12 priority 100
configure flow-redirect primary_GW nexthop 192.168.8.12 ping health-check interval 60 miss 3
configure access-list primary_GW vlan "Network" ingress
ACL Policy
entry Network1 {
if match all {
source-address 10.0.0.0/24;
destination-address 192.168.12.0/22;
} then {
permit;
redirect-name primary_GW;
LAYER2-3_SWITCH.116 # show iproute
Ori Destination Gateway Mtr Flags VLAN Duration
#d 10.0.0.0/24 10.0.0.1 1 U------um--f- Network 0d:1h:51m:5s
#d 192.168.8.0/24 192.168.8.36 1 U------um--f- GW_primary 0d:1h:52m:4s
#d 192.168.11.0/24 192.168.11.254 1 U------um--f- GW_secondary 0d:1h:51m:47s
#s 192.168.12.0/22 192.168.11.253 1 UG---S-um--f- GW_secondary 0d:0h:5m:45s
LAYER2-3_SWITCH.117 # show flow-redirect "primary_GW"
Name : primary_GW VR Name : VR-Default
Inactive Nexthops: Forward Health Check : PING
Nexthop Count : 1
Active IP Address : 192.168.8.12
Index State Priority IP Address Status Interval Miss
0 Enabled 100 192.168.8.12 UP 60 3
TAKING THE WRONG PATH
NET_PC> trace 192.168.12.1
trace to 192.168.12.1, 8 hops max, press Ctrl+C to stop
1 10.0.0.1 0.307 ms 0.358 ms 0.311 ms
2 *192.168.11.253 9.823 ms (ICMP type:3, code:3, Destination port unreachable)
NET_PC> ping 192.168.12.1
84 bytes from 192.168.12.1 icmp_seq=1 ttl=254 time=9.281 ms
84 bytes from 192.168.12.1 icmp_seq=2 ttl=254 time=6.840 ms
84 bytes from 192.168.12.1 icmp_seq=3 ttl=254 time=3.192 ms
84 bytes from 192.168.12.1 icmp_seq=4 ttl=254 time=2.802 ms
84 bytes from 192.168.12.1 icmp_seq=5 ttl=254 time=3.291 ms
If I remove the static route to the secondary gateway, it still doesn’t work.
As long as I put a default or static route in, I can get to either of the gateways and the desired network behind them, but only one of them.
ACL Policy
entry Network1 {
if match all {
} then {
permit;
Nexthop Count : 1
6 REPLIES 6
‎01-30-2016 04:09 PM
I don't like tests on vr environment .
I prefer test with real hardware. I know that sometimes it is a problem, but vr are good for simple things that don't require hardware. About the "echo and roundtrip time" in VR... I think we should ask guys from Extreme  --
Jarek
Jarek
‎01-29-2016 09:10 PM
Haha! Hey Jarek. It looks like it was the EXOS image I was using in my virtual environment. I loaded a 15.7.x.x image and everything worked. Weird thing is; the echos respond with type 3 unreachable, but it gives me a round trip response time. Is this correct? Is this the way it should work?
‎01-28-2016 09:30 PM
Jeff,
what switch (model) and EXOS you have ? I have done this now on my summit 250e and all is working well.
Jarek
Jarek
I have done last test on x250e and I think there was xos 15.3.3.5 installed, but I have also x670 with 15.6.3 p1-8 and flow redirect is working ok. -- Jarek
