10-20-2022 03:52 PM
I have bandwidth problems in AP305C with version 10.4, it does not exceed 100Mbps in a 1Gbps connection, what can I do to achieve better performance.
Help me Please.
08-01-2023 09:49 PM
From the get-go, we should know the contrast between MBps and Mbps.
MBps - MegaBytes per second
Mbps - Mega Bits per second
Here, the case is, your web access supplier gives you 100 Mbps which implies 100 Uber Pieces each second.
As a general rule, 8 bits = 1 byte.
Furthermore, the documents we, for the most part, see (or use) are regarding MegaBytes (MB).
Along these lines, your real web speed is 100/8 = 12.5 MBps.
Trust, this assists you with understanding.
Note: Even, the web speed to a specific gadget relies upon the associated gadgets associated with that organization (your association).
