What is the difference between an untagged port and a tagged port?
MUNIR_ENG
New Contributor III
What is the difference between an untagged port and a tagged port ? when can I using them & what is the benefit?
12 REPLIES 12
Bruce_Garlock
New Contributor II
I think you also need to 'untag' the native vlan (not default vlan) on any trunk ports.
Using a "native VLAN" on a trunk means not tagging this VLAN. This is not needed for Extreme EOS nor ExtremeXOS. I would recommend to tag every VLAN on any inter-switch-link. Note that some special configurations (e.g. RSTP on EXOS) do require a native VLAN, but those situations can usually be avoided (e.g. using MSTP instead of RSTP).
Ryan_Mathews
End user devices will need to be on an untagged vlan to get to the internet.
great , just i need know What is the function untagged, with what use, witch the benefit ?
