changing slot number in stack
  • Question
  • Updated 4 years ago
  • Answered
On my current working stack, i have 2 x670v and 2x440. I added another 2 x670v to the stack, I want to change the slot numbers of the current 2 x440 to a different stack number. By doing this, will the config also adapt to the change? or would i need to reconfigure it?
Setup is:
x670v <- Slot 1
x670v <- Slot 2
x670v <- Slot 5
x670v <- Slot 6
x440p <- Slot 3
x440p <- Slot 4
What i want:
x670v <- Slot 1
x670v <- Slot 2
x670v <- Slot 3
x670v <- Slot 4
x440p <- Slot 5
x440p <- Slot 6
Photo of Gene Fontanilla
Gene Fontanilla
  • 504 Points 500 badge 2x thumb
  • lucky
Posted 4 years ago
Photo of Dave Hammers
Dave Hammers, Dir SW Engineering
  • 3,552 Points 3k badge 2x thumb
You will need to reconfigure for the new slot number
Photo of Alexandr P
Alexandr P, Embassador
  • 12,576 Points 10k badge 2x thumb
Hi!
You need manually configure each slot number (which you want to change), like this:
# configure stacking node-address "xx:xx:xx:xx:xx:xx" slot-number 2
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,712 Points 3k badge 2x thumb
Beware thats the you might change youre configuration  when you change slot numbers.
Photo of Alexandr P
  • 12,476 Points 10k badge 2x thumb
not quite
in this case - probably Master is x670v <- Slot 1, so global configuration will be from Master and not changing, but ports configuration can change, like 4:10
Johan Hendrikx
Thats what I mean..  :)
Photo of Alexandr P
Then Like for you )))
Gene Fontanilla
Thank you for all the replies, now I am encountering issues with my x440s not finding the master node, and getting stuck at pending-AAA, I have checked all possible cause of this bug, but I haven't been successful, I have tried rebuilding the stack numerous times, but it still can't find the master node, even though i can see it in the "show stacking"
any advice on this?
Photo of PARTHIBAN CHINNAYA
PARTHIBAN CHINNAYA, Alum
  • 4,382 Points 4k badge 2x thumb
firmware version
same partition ---could you check this
master capability enabled or disabled
license ?
Photo of Alexandr P
You can see on front panel Master-node = 1
You can disconnect node on which you want to change stack#, in pending-AAA type REBOOT AS MASTER-CAPABLE, after reboot you can configure this node.
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,346 Points 10k badge 2x thumb
No information in the logs of the master node?
The x440s are configured as Standby node, not Master-Capable (as you are very likely to have a license mismatch)?
If you have unconfigured the x440s stacking config, have you configured back the enhanced protocol for stacking?
Gene Fontanilla
Hi
partition used = secondary
firmware = summitX-15.6.1.4.xos
x440 = master capability not enabled
enabled enhanced protocol.
will attach screenshots
Is the partition same on all switches in stack ?
Gene Fontanilla
x670v switches have the same partition settings, i think x440 has different partition.
Gene Fontanilla
As you can see, slot 3 which is the x440 switch, can be seen in the stack topology but cannot be configured, and is unable to see the master node. causing it to be stuck at AAA
(Edited)
Put the x440 in same partition as the x670 switches
This will solve ur problem
Gene Fontanilla
if you mean, all on secondary? it is already in it. if not, what do you mean? how do I do this?
(Edited)
you might have to load the image again to x440's so that it is loaded to the right partition
then reboot.
You should be able to do this slot by slot.
check if you have the below commands
download image <tftpip> image.exos partition <name> slot 3/4
Easiest way to upgrade x440 's as standalone to the right partition and add it to stack again
Gene Fontanilla
hi,
I have done what you have suggested, and still this persists :(
could you check the license level on all switches.
you can edit stacking license on x440.
Gene Fontanilla
hi parthiban,
this is the current settings:
 show stacking configuration
Stack MAC in use: <none>
Node               Slot         Alternate          Alternate
MAC Address        Cfg Cur Prio Mgmt IP / Mask     Gateway         Flags     Lic
*00:04:96:98:78:25 1   1   Auto <none>             <none>          CcEe--iNn Aa
 00:04:96:98:99:ba 2   2   Auto <none>             <none>          CcEe--iNn Aa
 00:04:96:97:a5:5c 3   3   Auto <none>             <none>          CcEe--iNn Aa
saw this on the log files:
02/24/2015 16:59:24.42 <Warn:DM.Warning> Slot-2: Slot-3 FAILED (1) License Mismatch
02/24/2015 16:59:24.37 <Warn:DM.Warning> Slot-1: Slot-3 FAILED (1) License Mismatch
02/24/2015 16:59:24.37 <Crit:NM.NodeStateFail> Slot-1: Slot-3 has failed for the reason of "License Mismatch".
(Edited)
Photo of Alexandr P
  • 12,192 Points 10k badge 2x thumb
That's mean - you have  License Mismatch :-)
Gene Fontanilla
yes, i get that, :P but i don't get where the license mismatch is, all are of the same setting :P
configure stacking {node-address node-address | slot slot-number} license-level[core | advanced-edge | edge]
Description
Allows you to restrict the license level at which the node operates.
Try this command and reboot the slot
Photo of Alexandr P
# show stacking slot X detail
will show you more information about what slot have license mismatch.
look at this outputs and compare them
Gene Fontanilla
Hi Parthibam,
THANK YOU VERY MUCH!
i found out what the problem is, our x440 doesn't have advanced edge license!
thank you for the patience on this matter.
regards! and more power
Its Glad to know you've found the problem.
Thanks for asking right questions in forum.
