dhcp cylic allocation for particular vlan
  • Question
  • Updated 3 years ago
  • Answered
we have extreme switch with following configuration
create vlan "vlan2001"
configure vlan vlan2001 tag 2001
configure vlan vlan2001 add ports 21-24 tagged
configure vlan vlan2001 add ports 10 untagged
configure vlan vlan2001 ipaddress 10.0.0.1 255.255.255.0
enable ipforwarding vlan vlan2001
configure vlan vlan2001 dhcp-address-range 10.0.0.3 - 10.0.0.100
configure vlan vlan2001 dhcp-options default-gateway 10.0.0.1
configure vlan vlan2001 dhcp-options dns-server 196.1.105.47
enable dhcp ports 21-24 vlan vlan2001
# show vlan2001 dhcp-config
DHCP Address Range   : 10.0.0.3->10.0.0.100
    Netlogin Lease Timer : Not configured (Default = 10 seconds)
    DHCP Lease Timer     : Not configured (Default = 7200 seconds)
    Default Gateway      : 10.0.0.1
    Primary DNS Server   : 196.1.105.47
    Ports DHCP Enabled   : 10, 21-24
Is it possible to tell switch to cycle through IP's .
say I have 20 devices . hey got 10.0.0.3-10.0.0.22
after two hours they should get 10.0.0.23-10.0.0.42
Next allocations will be 43-62 , 63-82 , (83-100 ,3,4) , 5-24 , ...
It should give new IP's till range gets exhausted .
Is that or something similiar possible ?
Photo of sumeet
sumeet
  • 798 Points 500 badge 2x thumb
Posted 3 years ago
Photo of JeremyClarkson
JeremyClarkson
  • 1,010 Points 1k badge 2x thumb
Not sure if you can get them to accept the next IP address in the range but you can adjust the lease.
configure vlan vlan2001 dhcp-lease-timer <lease-timer>
I believe the defualt value is 7200 seconds, you can adjust from 0 - 4294967295
OR - maybe look into DHCP Bindings
Thanks
(Edited)
Photo of sumeet
sumeet
can switch assign random IP's when DHCP lease expires ? instead of going to lowest free in 10.0.0.3-10.0.0.100 range .
Photo of Paulo Francisco
Paulo Francisco, Employee
  • 1,462 Points 1k badge 2x thumb
Typically clients will request the same IP they have at half (1/2) dhcp-lease-time. Normally DHCP servers will re-assign the client the same address (as requested by the client) since it matches the existing lease.
JeremyClarkson
Can i ask why you need clients to be assigned different IP?
Photo of sumeet
sumeet
Actually , our systems gives acknowledgement when device changes its IP . I guess , i am asking something non-standard .
