EMC - rename VLAN not working
  • Problem
  • Updated 2 years ago
  • Solved
Hi, my customer contacted me as renaming VLANs with EMC isn't working.
I've tried it with my EMC 7.0.4.29 and a D2 v06.03.15.0002 and see the same problem.
As I'm able to enable/disable ports on the D2 with EMC I'd say my SNMP settings are OK.
The txt file from the script log....
root@ControlCenter.labvienna.at:/usr/local/Extreme_Networks/NetSight/appdata/scripting/tmp/root$ cat 3_172_24_24_150_20160825-013501.txt
User: root
172.24.24.150    172.24.24.150    2016-08-25 at 13:35:01 CEST
*** Error at line - 881 ***
This script is only supported for Extreme switches.
Is the rename function for VLAN really only supported/working for XOS ?
Where could I find the EMC restrictions - is there some document available.
Thx,
Ron
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 47,040 Points 20k badge 2x thumb
Posted 2 years ago
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,610 Points 1k badge 2x thumb
Ronald,
the current scripts are only created for EXOS devices. The D2 you need still configured via the Java client. We are working on an global solution which will allow to deploy and change the vlans in EOS and EXOS in the same ways.
regards
Bastian
(Edited)
Thanks Bastian, in which document could I find this information/restrictions.
BR,
Ron
