ERPS 4 rings? - Edge License
  • Question
  • Updated 2 years ago
  • Answered
Hello, all!
Stack of 2 switches X440.
License Edge.
Trying to create few ERPS rings.
With this license I can create 4 rings (4 max rings with matching ring ports).
I have 2 rings:
Slot-1 x440-24t-Stack1.15 # sh erps
ERPS Enabled: No
ERPS Display Config Warnings: On
ERPS Multicast Add Ring Ports: Off
ERPS Multicast Send IGMP and MLD Query: On
ERPS Multicast Temporary Flooding: Off
ERPS Multicast Temporary Flooding Duration: 15 sec
Number of ERPS instances: 2
# ERPS ring configuration :
Ring           State           Type    East    West    Control-Vlan   VID
ring1          Disabled        R r     1:21    +2:21     z_ring1_ctrl  (4091)
ring2          Disabled        I       --      --       z_ring2_ctrl  (4092)
But when I try to add ring-port to ring2 I receive error:
Slot-1 x440-24t-Stack1.11 # configure erps ring2 ring-port east 1:22
Error: Current switch license level does not allow to configure the use of more than two ring ports
Configuration failed on backup Node, command execution aborted!
Is it because ring2 is sub-ring?
Can you, please, explaine me Edge restriction about 4 rings?
Is it mean that phrase "4 max rings with matching ring ports" mean that I can create max 4 rings but ring-ports have to be the same?
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,742 Points 10k badge 2x thumb
Posted 2 years ago
Photo of Necheporenko, Nikolay
Necheporenko, Nikolay, Employee
  • 1,600 Points 1k badge 2x thumb
Hi Alexandr!
The restriction for "Edge License level" means that all four ERPS domains should share same ring ports.
Photo of Alexandr P
Thank you , Nikolay!
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Photo of Alexandr P
Hi!
How many ring-ports we can create with AdvEdge and with Core license?
Thank you!
Photo of Henrique
Henrique, Employee
Hi, you can create up to 32 domains with different ring ports for Advanced Edge/Core Licenses.
Photo of Alexandr P
Thank you!
If I don't wrong there was limitation in earlier EXOS version?
Photo of Henrique
Henrique, Employee
I saw same behavior for Advanced Edge in a EXOS switch with 15.3.x and 16.x versions.
Didn't get any license error after creating 32 ERPS domains with 32 different east ports.
Photo of Alexandr P
Thank you all for help!!!
