EWC and Purview Analytics don ́t work together...
  • Problem
  • Updated 10 months ago
  • Solved
  • (Edited)
Hello Friends,
after annoying 5 hours test i ́m very frustrated.
I upgraded my lab to EWC V10.41 with the latest purview /Analytics / netsight 8.015
First i did a flat test, EWC ETH0 / Purview ETH0 / SSID for Testing.
All together were in one VLAN, they were terminated on a VMware Host with virtual Nic set to VLAN4095 and the Port on the Switch was PVID and Untagged on VLAN 100 ..
That ́s worked fine Without Problems.
After that i wanted to build up a more Standard and Secure Solution.
EWC ETH 0 and Purview ETH 0 are into the same vlan. ( 101 )
WLAN Traffic is configured as Bridged@EWC (with VLAN Taged 100)
I have configured Netflow in EWC as described into the guides, IP of ETH0 Purview Appliance
Mirror Port : None
But there is no NetFlow Traffic arrive on the ETH0 Interface of Purview Appliance and i dont know why anymore.
I checked this with : tcpdump -i eth0 udp port 2095 on the Pureview appliance.
I can ping from purview eth0 to EWC eth0.
I made a cap file on the eth0 of the EWC an no packet is going into direction of purview.
I made some pings from purview to ewc and again a Network dump with packet capture..and with wirshark i can see the icmp packets coming from Purview and going to purview.
At this time i don ́t know where i can still search for this error....
Perhaps someone of you can read something into the cap file, i will attach this.
The file was recorded as i pinged from ewc eth0 to purview eth0 and reverse.
IP : 192.168.50.4  ( EWC eth0 )   192.168.50.12 ( Purview eth0)
Some Questions for me:
1. what ist the source Interface of NetFlow Data from EWC, is this ETH0 in every Situation ?
2. which deployment is the right for Integration of an ewc to purview.
As i understand this should be single Interface but Without GRE Tunnel ....
how can i configure this, or do i Need a gre tunnel Between the EWC and the Purview for
using NetFlow Without dedicated L2 Mirror ?
Christian
Dropbox Link to cap file
https://www.dropbox.com/s/wnqwx9g67j9a9gs/mgmt_traffic_dump4.cap?dl=0
if the Standard questions are coming :-)
- yes NetFlow is activated in Advanced WLAN Services of SSID
- yes Traffic Mirror is activated on the main tab of WLAN Services
- yes Appliaction Visibility is activated on the same tab
- yes traffic mirror is activated into the designated role for this SSID / VNS
Photo of info@systemhaus-genthin.de
Posted 10 months ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 9,854 Points 5k badge 2x thumb
The best practise is:
Do not use Admin interface (out-of-band) (disconnect).
Use only one (exactly one) physical topology (you can have as many as you need B@AP, B@EWC, routed...)
The physical topology should be used for netflow export.
Good luck.
thx.. i will test it, but one question
How can i definitely check that NetFlow packets will sent out from EWC ?
I am using tcpdump on the EWC...
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,536 Points 3k badge 2x thumb
Hi ,
Just wanted to check , is this taken care now ? are you able to complete the set up ?
Thanks,
Suresh.B
..  :-( no ... i ́m very frustrated .. the EWC seems to strike against my whishes
i did a   "tcpdump -i any -n udp port 2095" on the EWC Shell and no Little packet is passing
Do you know any Rule (predefined) or Setting that could block this NetFlow Generation on EWC ?
I have only one physical topology ..
from this and from every other Interface i can ping the eth0 of purview appliance ..
but the EWC don ́t generate any packet of NetFlow .. as it seems.
Hi ,
Since you have all latest firmware's in your set up,
Could you open a GTAC case because you already very frustrated fixing this issue by yourself.
Thanks,
Suresh.B
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,174 Points 50k badge 2x thumb
Please disable the controller eth0/admin port (in VM) and replace the IP with a unused IP/subnet just to make sure it's not used.
I had a mirror setup till now (I was too lazy to change it) but now I've disabled/removed the mirror and configured it for IPFIX like this...
https://gtacknowledge.extremenetworks.com/articles/How_To/Configuring-a-Identifi-Wireless-Controller...
From my test you'd skip the controller config completely (screenshot#1) because if you just do the Analytics config (2nd screenshot) everything is done via EMC...
- EMC sets the Analytics IP on the controller
- EMC sets all the WLANs that you checkmark and configures the controller WLANs to "Default Traffic Mirror: enabled both directions"
!!! I've rx an error after I hit apply/save in EMC but still everything was fine !!!
After that one configuration step in Analytics I've rx NetFlow information (tcpdump -i eth0 udp port 2095) BUT I didn;t see anything with tcpdump on the controller... not sure why or whether that is FAD.... but give it a try and run the command on the Analytics instead of the controller (I know you'd like to check whether something is going out but I wasn't able to see packets even it was working).
Here the proof that EMC configured everything = controller audit UI log...
12/13/17 01:54:39NetsightvnswlansWLANS SecureAccess configuration changed:
12/13/17 01:54:39Netsightvnswlans[mirrorn] setting has changed from [0] to [1]
12/13/17 01:54:39Netsightvnswlans[netflow] setting has changed from [0] to [1]
12/13/17 01:54:39NetsightvnsgeneralNetflow MirrorN configuration changed: netflow_export_ip from 0.0.0.0 to 172.24.24.120,
From what I see it looks like that you don't need to set anything on the roles (mirror = disabled).
-Ron
(Edited)
