extreme cloud
  • Question
  • Updated 2 years ago
  • Answered
Hi All,
                   Am trying to adopt AP3805i-ROW  extreme cloud.AP showing critical alarm.
any ideas on that or when that issue gets fixed?
Photo of Mohammed Jasheer
Mohammed Jasheer
  • 916 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,894 Points 20k badge 2x thumb
Could you share more information about the critical alarm and a screenshot.
Mohammed Jasheer
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,706 Points 1k badge 2x thumb
Hi Mohammed,
Could you please confirm the device is AP3805i-ROW? I have seen the similar issue with Ap3805i-FCC AP trying to use the device group configured with country Asia.
Regards,
Nathiya M
Photo of Jason
Jason, Employee
  • 3,608 Points 3k badge 2x thumb
Hello Mohammed,
In addition to what Nathiya had suggested above, I would also recommend that the AP has the correct network time via NTP  and also has access to the internet.
Also, make sure that you do not have another local controller that the AP can connect too.
The article below may help:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-are-the-prerequisites-for-deploying-my-a...
As always, if you are not able to resolve it, please contact GTAC to open a case and we can assist.
Regards,
Jason
