How i configure LACP between Extreme and CISCO?
Daniel_Valera1
New Contributor II
Hi, I need configure LACP protocol between Extreme and cisco.
i have a BD-8810 SW i need configure two ports with LACP protocol but i dont have idea... the other equipment is a Cisco. i check in the command reference guide but that not say a lot
5 REPLIES 5
Jeremy_Gibbs
Contributor
Here is also a great article about Cisco and "port-channels"
http://www.freeccnaworkbook.com/workbooks/ccna/configuring-etherchannel-utilizing-lacp
BrandonC
Hi Daniel,
In addition to what Jeremy and Bernardo posted, this GTAC Knowledge article may help out as well:
https://gtacknowledge.extremenetworks.com/articles/How_To/how-to-configure-sharing-LAG-LACP-in-Summi...
-Brandon
Bernardo_Vallad
Check this guide for basic configuration in EXOS: http://packetflow.io/2015/01/extreme-networks-exos-cheat-sheet.html
Jeremy_Gibbs
Contributor
enable sharing grouping lacp (EXOS) Cisco: interface GigabitEthernet0/0/1 no ip address no negotiation auto channel-group 1 mode active end L3-UC#show run int gig 0/0/2 Building configuration... Current configuration : 103 bytes ! interface GigabitEthernet0/0/2 no ip address no negotiation auto channel-group 1 mode active end
