How to check connected SFP module Serial no. Part No. type and Info?
  • 2
  • 3
  • Question
  • Updated 3 years ago
  • Answered
Apart from these command? I tried these command but can't grab required info.
debug hal show optic-info slot 1
show ports 1:25 transceiver information detail
sh ports 2:25 information detail
Thanks.
Photo of Paul
Paul
  • 2,026 Points 2k badge 2x thumb
Posted 3 years ago
  • 2
  • 3
Photo of Sean Brady
Sean Brady
  • 318 Points 250 badge 2x thumb
I am running code 15.3.1.4patch1-44 on an x670v  and the output of show port transceiver info detail gives me the requested information.
sho ports transceiver information detail
Port :  1
    Media Type            : SF+_SR
    Vendor Name           : FINISAR CORP.
    Part Number           : FTLX8571D3BCL-EX
    Serial Number         : 1353P-00470
    Wavelength            : 850 nm
    Temp (Celsius)            :  26.30      Status               :  Normal
          Low Warn Threshold  : -8.00       High Warn Threshold  :  73.00
          Low Alarm Threshold : -13.00      High Alarm Threshold :  78.00
    Voltage AUX-1/Vcc (Volts) :  3.31       Status               :  Normal
          Low Warn Threshold  :  3.00       High Warn Threshold  :  3.60
          Low Alarm Threshold :  2.90       High Alarm Threshold :  3.70
    Tx Power (dBm)            : -2.18       Status               :  Normal
          Low Warn Threshold  : -5.00       High Warn Threshold  : -1.00
          Low Alarm Threshold : -6.00       High Alarm Threshold :  0.00
    Rx Power (dBm)            : -31.55      Status               :  Low Alarm
          Low Warn Threshold  : -18.01      High Warn Threshold  : -1.00
          Low Alarm Threshold : -20.00      High Alarm Threshold :  0.00
    Tx Bias Current (mA):        7.66       Status               :  Normal
          Low Warn Threshold  :  5.00       High Warn Threshold  :  12.60
          Low Alarm Threshold :  4.00       High Alarm Threshold :  13.20
Are you running an older train of code?  Do you get any output from that command?
Photo of Daniel Flouret
Daniel Flouret, Employee
  • 7,470 Points 5k badge 2x thumb
That command will work if the port and the transceiver support Digital Diagnostic Monitoring Interface (DDMI).
If you issue the command on a port that does not support DDMI you will get an error message like this:
Port 3:1 This command is not supported on this port. All ports and
transceiver of the ports requested in the command need to support DDMI.
If you issue the command on a port that supports DDMI, but the transceiver does not support it you will get an error message like this
Port 3:1 This media/transceiver does not support enhanced digital diagnostic
monitoring interface (DDMI). All ports and transceiver of the ports requested
The command is available on the following platforms:
• BlackDiamond 8800—10G8Xc, 10G4Xc modules and S-10G1Xc option cards with 10G XFP optics
• BlackDiamond 8900—10G8X-xl modules and S-10G1Xc option cards with 10G XFP optics
• Summit X250e switches—SFP ZX and LX100 optics
• Summit X450a, X450e switches—SFP ZX and LX100 optics
• Summit X460 switch—SFP ZX and LX100 optics
• Summit X480 switches and X480 VIM2-10G4X—XFP and SFP ZX and LX100 optics
• Summit X650 switches—SFP ZX and LX100 optics —SFP+ optics ER/LR
• Summit X670 switches—SFP ZX and LX100 1G optics —SFP+ 10G optics
Photo of Paul
Paul
Thanks all. :D
Photo of Jan Steinbach
Jan Steinbach
  • 1,192 Points 1k badge 2x thumb
Hello at all,
In this context:
Is there an SNMP OID avaible, to get the "Media Type" and/or even the Partnumber?
(f.e. Order P/N 10051H for the 1000BASE-SX SFP - http://learn.extremenetworks.com/rs/extreme/images/1000Base-SFP-Optics-DS.pdf)
Cheers,
Jan
(Edited)
Photo of Drew C.
Drew C., Community Manager
  • 40,206 Points 20k badge 2x thumb
Hi Jan,
This is on the list of things we've asked for, but it hasn't been implemented in EXOS yet.
-Drew
Photo of Renato Santos
Renato Santos
  • 110 Points 100 badge 2x thumb
Drew, there are MIB to monitor the power transceiver by SNMP in the summit x450, 460 and x670? If have, what MIB's?
Photo of Drew C.
Hi Renato, this feature isn't available in the MIB yet.
Renato Santos
Hi Drew!
I need to edit some cfg files. Is it possible to send me the download page for File Manager App?
Thanks!!
Photo of Drew C.
  • 36,792 Points 20k badge 2x thumb
This belongs in a new discussion.
Please reference the new conversation here: Editing config files
Renato Santos
Oh!! Thanks excuse me
