How to combine Selective QinQ CEP with standard tagged vlan on a port?
  • Question
  • Updated 3 years ago
  • Answered
If i read the documentation correctly it should be possible to combine standard tagged Vlans and VMAN Selective QinQ CEP on one port? I just can't figure out how to get it working. When i enable CEP the CLI says:
Error: 45: Port cannot belong to VLAN and a VMAN at the same time
Does anybody have any experience with this configuration?
Photo of Michael Scharn
Michael Scharn
  • 160 Points 100 badge 2x thumb
Posted 3 years ago
Michael Scharn
Official Response
Hi Oscar,
I have the X670 G1 as core switches.
I just found the problem. If a port is connected to the default VLAN 1 it does not work.
You have to take the port out of Vlan 1 default and then the CEP function works without issue..
Should be noted in the documentation.. :)
Thanks for the help!
Photo of OscarK
OscarK, ESE
  • 7,702 Points 5k badge 2x thumb
Official Response
Hi Michael, you cannot have a vman and a vlan untagged to a port, so this default vlan that is on all ports by default was causing the problem.
Thanks for the update and finding the cause.
