igmp snooping & vlan routing Extreme 220
  • Question
  • Updated 2 months ago
  • Answered
The admin guide for the Extreme 220 says "If an interface has IGMP Snooping enabled and you enable this interface for routing or enlist it as a member of a port-channel (LAG), IGMP Snooping functionality is disabled on that interface." Does this mean that there is no way to do inter-vlan routing and use IGMP snooping at the same time?
Photo of Mike Assel
Mike Assel
  • 80 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Steve Geisser
Steve Geisser, Employee
  • 342 Points 250 badge 2x thumb
Hello Mike,
This would only affect you if you were to configure a routed interface on a physical port.  In most cases, you would want to create a vlan interface and use that for inter-vlan routing.  In that case, snooping won't be disabled on any physical interface.  However, the switch does not support any multicast-routing functionality.  I know that isn't what you were asking, just FYI.
Here are a few articles that should help:
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-is-the-difference-in-putting-an-iP-addre...
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-IP-Helper-on-ExtremeSwitc...
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-vlan-routing-on-200-serie...
I hope this helps.  If you have any additional questions or need help setting this up, you can always call into the GTAC (800-872-8440) and get assistance from an experienced tech.
Best Regards,
Steve Geisser
Escalation Support Engineer
Extreme GTAC
Photo of Mike Assel
Mike Assel
Thanks Steve. I'm not sure what I was doing wrong the first time, but it's all working now. Thanks for the clarification.
