Is there a guide for configuring WiNG's onboard RADIUS server?
  • Question
  • Updated 1 year ago
  • Answered
Hi  Do you have a guide to getting the onboard Radius server working in V5.8.5 when using DOT1X and MSCHAPV2, I have set this up and it all looks to be working but the radius times out, shows its running but I don't think it is ( this is on the RFS7000 using a mixture of 7131 and 7532 AP's )
Note: This conversation was created from a reply on: 2017-10-09: New GTAC Knowledge Articles October 01 - 07, 2017.
Photo of Phil storey
Phil storey
  • 1,254 Points 1k badge 2x thumb
Posted 1 year ago
Photo of Wei Pin Lim
Wei Pin Lim, Employee
  • 340 Points 250 badge 2x thumb
Hi Phil, the two links below will help on your question.
How to configure 802.1x authentication with internal RADIUS on a WiNG controller -
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-802-1x-authentication-wit...
How to configure a WiNG controller for 802.1x authentication with internal RADIUS, using LDAP to connect to a Windows Active Directory server -
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-a-Summit-WM3000-for-802-1...
Photo of Timo
Timo
  • 3,230 Points 3k badge 2x thumb
If you use EAP-MSCHAPv2, use a certificate from your PKI, if you have a PKI. If not you need to distribute the self sign cert.
Do not disable the certificate check at your clients!
