Management Center Installation Requirements
  • Question
  • Updated 1 year ago
  • Answered
When reading the Management Center installation guide it mentions the server requirements for small, large and enterprise installations. I assume this is referring to the number of devices being managed but there is no indication of the limitation of each installation. Can anyone shed some light on this?
Also, are different licenses required for each of these levels?
Photo of Paul
Paul
  • 342 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,536 Points 3k badge 2x thumb
Hi Paul,
May I know what kind of limitation’s that you are looking for in specific,
 I can see below details from release notes.(page no#7)
Extreme Management Center Server
Small Medium Enterprise Large Enterprise
Total CPUs 1 2 2 2
Total CPU Cores 8 16 16 16
Memory 16 GB 32 GB 64 GB 64 GB
Disk Size 240 GB 480 GB 960 GB 1.92 TB
IOPS 200 200 10,000 10,000
Recommended scale based on server configuration:
Maximum APs 250 2,500 25,000 25,000
Maximum Wireless MUs 2,500 25,000 100,000 100,000
Maximum Managed Devices 100 1,000 10,000 10,000
Access Control End-Systems N/A 50,000 200,000 200,000
Statistics Retention (Days) 90 180 180 360
Application Analytics No Yes Yes Yes
MU Events No Yes Yes Yes
Thanks,
Suresh.B
Photo of Paul
Paul
The customer currently have around 90 nodes consisting of Summit switches some of which are stacks of 2 or more members. Would this be covered by the Small deployment?
They currently use Netsight and I believe this runs on a Windows Server.
Hi Paul,
I guess to get better answer on this part we have to check with Deployment team,
Thanks,
Suresh.B
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,470 Points 5k badge 2x thumb
Just to add to this regarding licensing.
Licenses also comes with a managed device count, so if you have 100 managed devices you could install and configure for "Enterprise" level and still have an NMS-100 type license.
So licensing is independent from server size.
Thanks
-Ryan
Photo of Paul
Paul
So the level is just a guidance for number of devices likely to managed and the device count licensing dictates the number of devices?
Yep,
Licensing will dictate number of devices and what feature sets are unlocked. (NMS-BASE, NMS, NMS-ADV)
Thanks
-Ryan
Photo of Bin
Bin, Employee
  • 5,372 Points 5k badge 2x thumb
Hello Paul,
There is one script which will you help to understand NMS license.
NetSight license - What options do I have for NetSight?
https://gtacknowledge.extremenetworks.com/articles/Q_A/What-options-do-I-have-for-NetSight
Thanks,
Bin
