Problem with adding secondry vlan interface on extreme C5G124-24P2 - Could not set the interface network.
  • Question
  • Updated 3 months ago
  • Answered
Hi all,
I am trying to set a secondary interface IP on VLAN 1. Due to business changes I needs to move away from their Class C network to a class B network. I am adding a secondry IP to be able to route between old and new network.
Here is what happens:
DetNet_Router(su)->router
DetNet_Router(su)->router>enable
DetNet_Router(su)->router#configure
Enter configuration commands:
DetNet_Router(su)->router(Config)#interface vlan 1
DetNet_Router(su)->router(Config-if(Vlan 1))#ip address 172.20.0.1 255.255.0.0 secondary
The primary interface on this vlan is 192.168.0.1 255.255.240.0
What am I doing wrong?
Thank you in advance.
Photo of JP Pieterse
JP Pieterse
  • 234 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,402 Points 5k badge 2x thumb
Just guess: the IP you are adding is already on different vlan?
JP Pieterse
I figured the same thing out. I manged to add 172.20.0.2.
I however cant find where 172.20.0.1 resides. Is there a command that I can run to find it?
Thanks for the reply
JP Pieterse
tried show interface - displays all vlan interfaces but the 172.20.0.1 is on none of them.
JP Pieterse
Just as a side note to all.
It looks like you have to shut down the interface before you can add secondary IP.
this is achieved by command "shutdown" when in router config mode.
you can start it again with command "no shutdown"
Photo of Jason Parker
Jason Parker, Employee
  • 2,898 Points 2k badge 2x thumb
show conf router
#Router Configuration
router
enable
configure
interface vlan 100
ip address 192.168.100.1 255.255.255.0
no shutdown
exit
interface vlan 200
ip address 192.168.200.1 255.255.255.0
no shutdown
exit
exit
exit
exit
(su)->router>en
(su)->router#conf
(su)->router(Config)#interface vlan 200
(su)->router(Config-if(Vlan 200))#ip address 10.58.166.1 255.255.255.0 secondary
show config router
router
enable
configure
interface vlan 100
no shutdown
exit
interface vlan 200
no shutdown
exit
exit
exit
exit
