problem with Config Booted on summit x450-g4
  • Problem
  • Updated 2 years ago
  • Not a Problem
when i configured switch this save configuration but if the switch reboot lost the configuration, i can see this configuration in the switch:
information on SW
Slot:             Slot-1 *                     Slot-2                                    ------------------------     ------------------------
Current State:    MASTER                       BACKUP (In Sync)
Image Selected:   secondary                    secondary
Image Booted:     secondary                    secondary
Primary ver:      16.1.0.18                    16.1.0.18
Secondary ver:    22.1.1.5                     22.1.1.5
Config Selected:  primary.cfg
Config Booted:    Factory Default
primary.cfg       Created by ExtremeXOS version 22.1.1.5
                  577404 bytes saved on Fri Jan 13 20:33:50 2017
Photo of Salvador Gallo
Salvador Gallo
  • 452 Points 250 badge 2x thumb
Posted 2 years ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,674 Points 10k badge 2x thumb
Hello Salvador,
You checked the "show config" to see if the config is missing? This is a stack, did you reboot the entire stack?
Salvador Gallo
yes, i reboot the stack and the config lost, yesterday config this in the sw:
BootRom > config none
BootRom > boot
after this config the switch lost the config the switch up with  factory default
Patrick Voss, Alum
Is there a reason you went to the bootrom and config none?
Salvador Gallo
i need to restore to factory and in enterasys this was the procedure and i suppose that the process was the same
Patrick Voss, Alum
Hello Salvador,
Can you explain the order of events? Config, Bootrom, Reboot?
unconfigure switch all will factory restore the configuration in exos. This is assuming you can login.
(Edited)
Salvador Gallo
is all
Patrick Voss, Alum
In what order?
Salvador Gallo
ok, in this case reboot the switch and them press space bar and put de command config none and reboot, after when i configure save configuration and reboot the switch lost the configuration
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
Please emphasize on the order in which it was accessed......We knew t hat you had factory defaulted the switch to unconfigure all.
Photo of Prashanth KG
Prashanth KG, Employee
  • 5,300 Points 5k badge 2x thumb
HI Salvador,
As per the output of show switch, the switch is booted with the "factory default" configuration.
If we reset the switch with the command below,
This is an expected behaviour that the switch will boot with the factory default configuration after the command above in the bootrom.
We might have a problem if you jus reboot the stack now and if it not loaded with the primary.cfg as mentioned above. So, please clarify the issue so that we can help you further.
Thanks.
