RADIUS authentication with our switch EXOS
  • Problem
  • Updated 2 years ago
  • Solved
I’m trying to configure RADIUS authentication with our  switch EXOS
I’m keep on getting this error
Note: Shared secrets created with EXOS 16.1 and greater are not compatible with EXOS 15.x and earlier.
we are using  ExtremeXOS version 21.1.1.4 21.1.1.4-patch1-2 by release-manager
          on Fri Apr 15 12:41:44 EDT 2016
Photo of Siva
Siva
  • 710 Points 500 badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
This is not an error, it is just a notification. It means the radius secret would not work if you downgrade this switch to a lower version and use the same config file.
Photo of Siva
Siva
Thanks OscarK
its working I can login with my AD password but now I can't make any changes seems i have remove my Privileges can u assist me on this  ?
* Slot-1 Clickatell-Access-SW1.1 > show configuration
This user does not have permissions for this command.
* Slot-1 Clickatell-Access-SW1.2 >
Photo of OscarK
OscarK, ESE
TO be admin you must add an option that the user has admin right. Please search on gtacknowlegde.extremenetworks.com for that, there is an article describing that.
Photo of Drew C.
Drew C., Community Manager
  • 40,070 Points 20k badge 2x thumb
Photo of Siva
Siva
Thanks Drew C
