RFS4000 act as router to cable modem?
  • Question
  • Updated 1 month ago
I am having difficultly getting an RFS4000 to connect to my ISP through my cable modem. I am new to AP controllers. I would assume(correct me if I am wrong) that the RFS4000 could replace my router. I also have 2 APs that I am going to deploy with the RFS4000.
Does not connect to internet: RFS4000 ---> cable modem ---> Internet
Connects to internet: RFS4000 ---> router ---> cable modem ---> internet
Photo of Nathan Derichsweiler
Posted 1 month ago
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,610 Points 4k badge 2x thumb
You may need to reboot the cable modem to release the old IP/MAC reservation.
do you have a lan & wan VLANs created on the RFS? can you share your configuration?
via shh provide the output of command 'show run'
(Edited)
Photo of Michael (Misha) Elin
Michael (Misha) Elin, SE
  • 476 Points 250 badge 2x thumb
To my understanding using cable box in bridging mode will require DHCP, static IP or PPPoE on router side. All is supported on RFS (and any WiNG) device. Please start with DHCP like:
interface up 1
switchport mode access
switchport access vlan 2100
interface vlan 1
ip address dhcp
ip dhcp client request options all
ip nat outside
Please also note that some services (like SIP) will require additional care because ALG provided in WiNG will not change packet headers as many home routers do.
Also you will not expect upnp support on enterprise grade device )
Misha
Photo of Christoph S.
Christoph S., Employee
  • 3,230 Points 3k badge 2x thumb
Which device is current the DHCP server and handling natting?
rfs4000-6F9F96#show run
! Configuration of RFS4000 version 5.9.2.0-032R
version 2.5
client-identity-group default
 load default-fingerprints
ip access-list BROADCAST-MULTICAST-CONTROL
 permit tcp any any rule-precedence 10 rule-description "permit all TCP traffic"
 permit udp any eq 67 any eq dhcpc rule-precedence 11 rule-description "permit D                       HCP replies"
 deny udp any range 137 138 any range 137 138 rule-precedence 20 rule-descriptio                       n "deny windows netbios"
 deny ip any 224.0.0.0/4 rule-precedence 21 rule-description "deny IP multicast"
 deny ip any host 255.255.255.255 rule-precedence 22 rule-description "deny IP l                       ocal broadcast"
 permit ip any any rule-precedence 100 rule-description "permit all IP traffic"
ip access-list default
mac access-list PERMIT-ARP-AND-IPv4
 permit any any type ip rule-precedence 10 rule-description "permit all IPv4 traffic"
 permit any any type arp rule-precedence 20 rule-description "permit all ARP traffic"
ip snmp-access-list default
 permit any
firewall-policy default
 no ip dos tcp-sequence-past-window
mint-policy global-default
meshpoint-qos-policy default
wlan-qos-policy default
 qos trust dscp
 qos trust wmm
radio-qos-policy default
wlan wlan1
 ssid wlan1
 vlan 1
 bridging-mode tunnel
 encryption-type tkip-ccmp
 authentication-type none
 wpa-wpa2 psk 0 0123456789
meshpoint TestMeshpoint
 meshid TestMeshpoint
 shutdown
 beacon-format mesh-point
 control-vlan 1
 security-mode none
 no root
meshpoint nateMesh
 meshid nateMesh
 control-vlan 1
 allowed-vlans 1
 security-mode psk
 no root
smart-rf-policy "RF Policy"
auto-provisioning-policy auto
dhcp-server-policy DHCPRFS4K
 dhcp-pool VLAN20
  network 192.168.20.0/24
  address range 192.168.20.101 192.168.20.200
  default-router 192.168.20.100
  dns-server  8.8.8.8
dhcp-server-policy default
 dhcp-pool default-vlan-1
  network 192.168.1.0/24
  address range 192.168.1.140 192.168.1.200
  default-router 192.168.1.131
management-policy default
 no telnet
 http server
 https server
 rest-server
 ssh
 user admin password 1 8a59d906aa75dbabb356e237cd27bdb0063539a8cde956e9b70a2fe9cbb59800 role superuser access all
 snmp-server community 0 private rw
 snmp-server community 0 public ro
 snmp-server user snmptrap v3 encrypted des auth md5 0 admin123
 snmp-server user snmpmanager v3 encrypted des auth md5 0 admin123
ex3500-management-policy default
 snmp-server community public ro
 snmp-server community private rw
 snmp-server notify-filter 1 remote 127.0.0.1
 snmp-server view defaultview 1 included
ex3500-qos-class-map-policy default
ex3500-qos-policy-map default
l2tpv3 policy default
profile rfs4000 default-rfs4000
 autoinstall configuration
 autoinstall firmware
 crypto ikev1 policy ikev1-default
  isakmp-proposal default encryption aes-256 group 2 hash sha
 crypto ikev2 policy ikev2-default
 crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
 crypto ikev1 remote-vpn
 crypto ikev2 remote-vpn
 crypto auto-ipsec-secure
 crypto remote-vpn-client
 interface radio1
  wlan wlan1 bss 1 primary
 interface radio2
 interface up1
 interface ge1
 interface ge2
 interface ge3
 interface ge4
 interface ge5
 interface wwan1
 interface pppoe1
 use firewall-policy default
 use client-identity-group default
 ip dns-server-forward
 logging on
 ip nat inside source list default precedence 1 interface vlan2100 overload
 service pm sys-restart
 router ospf
 router bgp
 adoption-mode controller
profile ap8533 default-ap8533
 crypto load-management
 interface radio1
 interface radio2
 interface radio3
 interface bluetooth1
  shutdown
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
  ip address zeroconf secondary
 interface pppoe1
 logging on
 router ospf
profile ap82xx default-ap82xx
 interface radio1
 interface radio2
 interface radio3
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface wwan1
 interface pppoe1
 logging on
 router ospf
profile ap81xx default-ap81xx
 interface radio1
 interface radio2
 interface radio3
  shutdown
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface wwan1
 interface pppoe1
 logging on
 router ospf
profile ap7522 default-ap7522
 interface radio1
 interface radio2
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
 router ospf
profile ap7532 default-ap7532
 interface radio1
 interface radio2
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
 router ospf
profile ap7562 default-ap7562
 interface radio1
  placement outdoor
 interface radio2
  placement outdoor
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
 router ospf
profile ap8432 default-ap8432
 interface radio1
 interface radio2
  shutdown
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface pppoe1
 router ospf
profile ap7602 default-ap7602
 interface radio1
  rf-mode 5GHz-wlan
  antenna-mode 2x2
 interface radio2
  shutdown
  antenna-mode 1x1
  shutdown
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface pppoe1
 router ospf
profile ap7622 default-ap7622
 interface radio1
  rf-mode 5GHz-wlan
  antenna-mode 2x2
 interface radio2
  shutdown
  antenna-mode 1x1
  shutdown
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 router ospf
profile ap7502 default-ap7502
 interface radio1
 interface radio2
 interface ge1
 interface fe1
 interface fe2
 interface fe3
  no power
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
profile ap7612 default-ap7612
 interface radio1
  antenna-mode 2x2
 interface radio2
  antenna-mode 2x2
  shutdown
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
 router ospf
profile ap7632 default-ap7632
 interface radio1
  antenna-mode 2x2
 interface radio2
  antenna-mode 2x2
  shutdown
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
 router ospf
profile ap7662 default-ap7662
 interface radio1
  placement outdoor
  antenna-mode 2x2
 interface radio2
  placement outdoor
  antenna-mode 2x2
  shutdown
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
 router ospf
profile ap71xx default-ap71xx
 interface radio1
 interface radio2
 interface radio3
 interface ge1
 interface ge2
 interface vlan1
  ip address dhcp
 interface wwan1
 interface pppoe1
 logging on
profile ap6532 default-ap6532
 interface radio1
 interface radio2
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
profile ap650 default-ap650
 interface radio1
 interface radio2
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
profile ap6521 default-ap6521
 interface radio1
 interface ge1
 interface vlan1
  ip address dhcp
 interface pppoe1
 logging on
profile ap621 default-ap621
 interface radio1
 interface ge1
 interface vlan1
  ip address dhcp
 logging on
profile ap6511 default-ap6511
&nbsp
There is my config. Sorry its so long! I am also having some meshpoint issues(excessive flooding - TR RX bandwidth realllly high)...ugh.. First time configuring all of this. Still learning.
(Edited)
looks like you have the default config on it. Since you are still learning you may be better off using the Initial Setup Wizard. Please log in to the controller via GUI. Then click on the configuration tab, once there look for "Initial Setup Wizard" button on the bottom of the page.
