samsung galaxy j7 wireless connecting problem
  • Problem
  • Updated 11 months ago
  • Solved
hi
please help me  to solve this problem :
samsung galaxy j7 mobile have a problem to connect access point ap3825i
thanks
Photo of Mikaeil Beigpour
Mikaeil Beigpour
  • 550 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Rajesh Jeevendran
Rajesh Jeevendran, Employee
  • 354 Points 250 badge 2x thumb
Hi
Please provide the below details
Controller Model and code version ?
Does other clients connected to the same AP3825i fine ?
Do they connect to open ssid or 802.1x SSID ?
Is this an issue connecting to "a" radio or "g" radio.
Regards
Rajesh.J
Mikaeil Beigpour
hi
controller model is c5210 software version 10.11.1.210.
donot have problem with other device and mobile.
connect to 802.1x ssid.
use 5GHZ and 2.4GHZ (ac,b/g/n)
thanks
Photo of Nathiya Munuswamy
Nathiya Munuswamy, Employee
  • 1,706 Points 1k badge 2x thumb
Hi Mikaeil,
Is it an issue only with samsung galaxy j7 mobile or any Android devices?
Regards,
Nathiya M
Mikaeil Beigpour
hi
thanks
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,114 Points 50k badge 2x thumb
So what is the problem, please describe it in detail.....
Mikaeil Beigpour
hi
see wifi ssid and donot connect to that and usually refress and scan ssid in wifi windows.
thanks
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,536 Points 3k badge 2x thumb
Hi Mikaeil,
Let us know the client status in report and logs ?
if you connect any other SSID or wireless connection , are you able to connect  ?
Thanks,
Suresh.B
Mikaeil Beigpour
hi
donot able to connect any other ssid.
thanks
Photo of Jacob, Praveen
Jacob, Praveen, Employee
  • 1,022 Points 1k badge 2x thumb
Mikhail,
What is the Android version? Do you know the command to run a tail on the AP that you are trying to connect to and do a "grep" for the Samsung device's mac address?
Thanks
Mikaeil Beigpour
hi
vesion is 6.0.1
I give you the GTAC answer... upgrade to latest version 10.11.05.
Mikhail,
I recollect one of our customers reporting a similar issue with the same phone model. I believe this could be related to certain configuration parameters for roaming on your WLAN, specifically .11r.
Can you paste a screenshot of your WLAN configuration?
Thanks
Hi Mikaeil
Please create a Test SSID [open Authentication 5Ghz band]
Apply the above to one AccessPoint
On one Samsung Device,please install the below Google play store app
https://play.google.com/store/apps/details?id=org.wahtod.wififixer
Check if the devices is able to connect.
As you could see the Android APP on the mobile would show the association,ip assignment etc.
You could also send logs to your email address.
Please do this for open authentication,since you have specified the samsung does not connect to any ssid.
Then you could repeat the same for production SSID [open and 802,1x]
Send log in the app send a text file to your email. Please use send log every time you connect to a different SSID.
Please share your findings.
Regards
Rajesh
Mikaeil Beigpour
hi
my wireless configuration is :
Photo of Scott Whall
Scott Whall, Employee
  • 548 Points 500 badge 2x thumb
Mikaeil - Ron suggested the upgrade to 10.11.05, and I agree.  For now, while you are still running 10.11.01, disable Fast Transition and Management Frame Protection (on ALL of your configured WLANs).
Photo of Caio Serafim
Caio Serafim
  • 86 Points 75 badge 2x thumb
"disable Fast Transition and Management Frame Protection" - This worked for me!!! Thank you so much for the support my friend!!!
Mikaeil Beigpour
hi
with your help I can solved this problem.
thanks
(Edited)
So could you please tell us what you've done to fix it.
Fast Transition along with Management Frame Protection was disabled on the WLANs.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,616 Points 20k badge 2x thumb
(Edited)
