slow ssh response on extreme switch
  • 2
  • Problem
  • Updated 2 years ago
  • Solved
Hello,
I takes between 5 to 10 seconds until the SSH Login window appear, if I connect by SSH to the switch. I have the version 21.1.3.7 on the switches X440G2-48p-10G4 running. Do you have any idea, whats the reason for this?
Thanks, Yves
Photo of Yves Haslimann
Yves Haslimann
  • 898 Points 500 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Frank
Frank
  • 3,836 Points 3k badge 2x thumb
my first guess would be: is your switch in DNS and can the IP be reverse-resolved by your workstation?
   Frank
Photo of Nicolas Nguyen
Nicolas Nguyen, Employee
  • 170 Points 100 badge 2x thumb
Hello Yves,
Does it happen will all terminals (putty, secureCRT, etc...) ?
There was a SSH bug in the previous version (21.1.1 and 21.1.2) but it should be corrected in your version.
Regards,
Nicolas
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,076 Points 5k badge 2x thumb
I like both replies. Check DNS, and does it happen on all terminals. Are you saving the SSH Public key when connecting, or do you choose to download it each time?
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
I have the same problem with all EXOS switches running 22.2.1.5. I had several open at GTAC cases, but they were never corrected or fixed. After the initial slow login, SSH response normally when running commands. I can post the verbose output from my SSH client later.
Yves Haslimann
Thanks for your replies. I checked DNS. But it's much faster by telnet, so in this case this seems to be a SSH problem, and not a DNS. And yes, I saved the key.
Photo of Frank
Frank
So your DNS is configured to reverse-resolve the IP address of the switch? You can check that in Unix/Linux via "dig -x ip.address" or in Windows with "nslookup ip.address" (and look at the last two lines, "Name" and "Address")
It's not really a DNS problem, it's that SSH has a problem if the reverse resolution fails.
Yves Haslimann
No, I connect by the IP address to the switch. So the switch doesn't send any DNS requests.
Photo of Frank
Frank
Sorry that I was unclear: It's the workstation that you connect from that wants to be able to reverse-resolve the IP address of the switch.
Yves Haslimann
I guess it was a DNS problem. I've configured the DNS AND the suffix, and it's good now. Thanks for your help. Besr regards.
