slx 9140 trunk configuration
  • Problem
  • Updated 3 months ago
  • Solved
When I try to configure a trunk port on the slx 9140 I get following error
Testsystem02(config)# interface Ethernet 0/1
Testsystem02(conf-if-eth-0/1)# Switchport mode trunk
%%Error: Interface not bound to bridge
Do you have any hints?
Photo of Giuseppe Casablanca
Giuseppe Casablanca, Employee
  • 130 Points 100 badge 2x thumb
Posted 3 months ago
Photo of Mick Day
Mick Day, Employee
  • 150 Points 100 badge 2x thumb
Hi I am not familiar with this specific error, but to configure a switchport to trunk mode, first you need to enable switching on the interface.
switchport
switchport mode trunk
Regards
Mick
Unfortunately no. It doesn't work.
Photo of Mick Day
Mick Day, Employee
Could you please include the rest of your configuration, so that the error can be put into context
Testsystem02# sh run
clock timezone Etc/GMT
hardware
 profile tcam default
 profile route-table default maximum_paths 8
 system-mode default
http server use-vrf default-vrf
http server use-vrf mgmt-vrf
logging raslog console INFO
logging auditlog class SECURITY
logging auditlog class CONFIGURATION
logging auditlog class FIRMWARE
logging syslog-facility local LOG_LOCAL7
logging syslog-client localip CHASSIS_IP
switch-attributes chassis-name SLX9140
switch-attributes host-name Testsystem02
no support autoupload enable
support ffdc
resource-monitor cpu enable threshold 90 action raslog
resource-monitor memory enable threshold 100 action raslog
resource-monitor process memory enable alarm 1000 critical 1200
snmp-server contact "Field Support."
snmp-server location "End User Premise."
snmp-server sys-descr "Brocade BR-SLX9140 Router"
snmp-server enable trap
system-monitor fan threshold marginal-threshold 1 down-threshold 2
system-monitor fan alert state removed action raslog
system-monitor power threshold marginal-threshold 1 down-threshold 2
system-monitor power alert state removed action raslog
system-monitor temp threshold marginal-threshold 1 down-threshold 2
system-monitor cid-card threshold marginal-threshold 1 down-threshold 2
system-monitor cid-card alert state none action none
system-monitor compact-flash threshold marginal-threshold 1 down-threshold 0
system-monitor MM threshold marginal-threshold 1 down-threshold 0
system-monitor LineCard threshold marginal-threshold 1 down-threshold 2
system-monitor LineCard alert state none action none
system-monitor SFM threshold marginal-threshold 1 down-threshold 2
telemetry profile system-utilization default_system_utilization_statistics
..truncated
telemetry profile interface default_interface_statistics
..truncated
line vty
 exec-timeout 10
threshold-monitor Buffer limit 70
vrf mgmt-vrf
 address-family ipv4 unicast
  ip route 0.0.0.0/0 172.17.0.1
 address-family ipv6 unicast
ssh server key rsa 2048
ssh server key ecdsa 256
ssh server key dsa
ssh server use-vrf default-vrf
ssh server use-vrf mgmt-vrf
telnet server use-vrf default-vrf
telnet server use-vrf mgmt-vrf
role name admin desc Administrator
role name user desc User
aaa authentication login local
aaa accounting exec default start-stop none
aaa accounting commands default start-stop none
service password-encryption
username admin password "BwrsDbB+tABWGWpINOVKoQ==\n" encryption-level 7 role admin desc Administrator
username user password "BwrsDbB+tABWGWpINOVKoQ==\n" encryption-level 7 role user desc User
cee-map default
 precedence 1
 priority-group-table 1 weight 40 pfc on
 priority-group-table 15.0 pfc off
 priority-group-table 15.1 pfc off
 priority-group-table 15.2 pfc off
 priority-group-table 15.3 pfc off
 priority-group-table 15.4 pfc off
 priority-group-table 15.5 pfc off
 priority-group-table 15.6 pfc off
 priority-group-table 15.7 pfc off
 priority-group-table 2 weight 60 pfc off
 priority-table 2 2 2 1 2 2 2 15.0
 remap lossless-priority priority 0
vlan 1
vlan 5
 name test
vlan 3820
 router-interface Ve 3820
 name LAN-Switch
qos map cos-mutation all-zero-map
...truncated
protocol lldp
 system-description Brocade BR-SLX9140 Router
vlan dot1q tag native
police-remark-profile default
class-map cee
class-map default
no protocol vrrp
no protocol vrrp-extended
interface Ve 3820
 ip proxy-arp
 ip address 172.17.0.8/21
 shutdown
interface Management 0
 no tcp burstrate
 no shutdown
 vrf forwarding mgmt-vrf
 no ip address dhcp
 ip address 172.17.0.7/21
 switchport
 switchport mode access
 switchport access vlan 1
 no shutdown
interface Ethernet 0/2
 switchport
 shutdown
..truncated
Photo of Michael Dinius
Michael Dinius, Employee
  • 250 Points 250 badge 2x thumb
hi Giuseppe ,
what version you are running ??
17s.1.00
tried on my device here and it woked . (9240)  downgraded to your version
so  you can try  on the port a    "no switchport"    -->  "switchport " --->  " switchport trunk"
if  you still see the same error message i suggest to open a case with GTAC
