trying to add access points to Virtual Controller in VLAN 998 fails
  • Problem
  • Updated 1 year ago
  • Solved
I created a config on a AP7552Express via the GUI but now I'm unable to adopt additional access points to the configuration.
I have changed the default VLAN into 998 and added an IP to it.
  •  INTERFACE          IP-ADDRESS/MASK            TYPE        STATUS   PROTOCOL
  •  vlan1              unassigned                 n/a         UP       up
  •  vlan300            unassigned                 n/a         UP       up
  •  vlan301            unassigned                 n/a         UP       up
  •  vlan998            10.240.130.130/26          primary     UP       up
but when I boot the 2nd AP it fails with the following error;
 %USER-3-ERR: main.pyo: * * ERROR: add new client config failed
 %USER-3-ERR: main.pyo: * * ERROR: 3 - /wing-config/device[mac=74-67-F7-A5-67-A8] Overloaded interface vlan1 in NAT config is not present
How should I configure the VC to start adopting?
Or do they really need to be in VLAN1 for this?
Photo of Ronald Groenewegen
Ronald Groenewegen
  • 364 Points 250 badge 2x thumb
Posted 1 year ago
Photo of Ondrej Lepa
Ondrej Lepa, Employee
  • 5,638 Points 5k badge 2x thumb
Hi Ronald,
could you attach a running configuration from the virtual controller?
By default the VLAN1 is expected to broadcast adoption requests and SwiftUI is designed to be simple system, hence a certain configuration is expected here.
I would recommend first to get that AP adopted by VC and then change the VLAN assignation.
Regards,
Ondrej
Ronald Groenewegen
Hi Ondrej,
I cannot share the configuration yet. It was lost after I accidently disabled GE1 as stated in the other post I have ;-)
I'm currently recreating the config so I guess I will leave the default VLAN at 1 instead of changing it into 998.
Ronald Groenewegen
I was able to create a working config, it now adopts the other access points via VLAN 998.
#case closed.
