TTL expired in transit!
  • Problem
  • Updated 5 days ago
Hi Friends,
Good day.
I have problem with Inter-Vlan.
Our goal is PC1 must communicate to PC2 with different VLANs. same as PC2 to PC1.
We followed this link below as guide. https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-inter-VLAN-routing-in-EXOS
But seems inter-VLAN is not working because PC1 not successfully PING the PC2, same as PC2 to PC1. When we tried to ping each PC the ping is "TTL expired transit". but zero packet loss.
We tried this set up to our X440-G2. with the same configurations with the above GTAC link guide.
Thanks,
Resolut1on
Photo of Resolut1on
Resolut1on
  • 824 Points 500 badge 2x thumb
  • sad
Posted 1 week ago
Photo of Aman Choubey
Aman Choubey
  • 754 Points 500 badge 2x thumb
Did you Enable the Ip forwarding Globally?
Are you able to ping the gateway from both PC?
If you are not able to ping the Gateway switch off the Window firewall and try once.
(Edited)
Photo of Resolut1on
Resolut1on
  • 814 Points 500 badge 2x thumb
Yes, I already enable the ipforwarding from both VLAN, turn off the firewall of both PC.
PC1 10.10.10.10 can only ping 10.10.10.1 gateway.
PC2 20.20.20.20 can only ping 20.20.20.1 gateway
Aman Choubey
You have to enable IPFORWARDING GLOBALLY Also.
else check the ACLs.
(Edited)
Photo of Resolut1on
Resolut1on
Hi Aman, I already configured the "#enable ipforwarding"
I also following the GTAC guide on the link above.
concern not yet resolve.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 45,586 Points 20k badge 2x thumb
Cool story, but not many technical infromation included, how about a network diagram and the config of the switch or at least a screenshot of "show vlan".
Are you able to ping the PCs from the switch, please provide also a screenshot of the results.
Photo of Resolut1on
Resolut1on
Please see screenshots below:
Photo of David Rahn
David Rahn
  • 888 Points 500 badge 2x thumb
Does the swith pass traffic in 1 vlan? I know there was a glitch on some switches that the default config had unicast fordwarding disabled. If we has all output from show config we could see that
If you can not find any other culperate...
Back on the x450 (g1) the ttl can be changed in switch via snmp command.
I had this with a used switch once, eveything looked on except the ttl was reduced to far. To be usable.
And is not visable in show config
And as far as i know this did not set back when the switch qas defaulted. You have to use an snmp tool to reset the value.
I will look for the doc on that and share.
Photo of Resolut1on
Resolut1on
Thanks David, did you already found the doc? Even default vlan cannot pass through other vlan.
Inter-vlan routing not working
Photo of David Rahn
David Rahn
https://community.extremenetworks.com...
The comments under that question has the info i used to determine if this is the issue.
You should post whole config for best help
Photo of Resolut1on
Resolut1on
* X440G2-12p-10G4.23 # show configuration
# Module devmgr configuration.
configure snmp sysContact "support@extremenetworks.com, +1 888 257 3000"
configure sys-recovery-level switch reset
# Module vlan configuration.
configure vlan default delete ports all
configure vr VR-Default delete ports 1-16
configure vr VR-Default add ports 1-16
configure vlan default delete ports 1-2
create vlan "v10"
configure vlan v10 tag 10
create vlan "v20"
configure vlan v20 tag 20
configure vlan Default add ports 3-16 untagged
configure vlan v10 add ports 1 untagged
configure vlan v20 add ports 2 untagged
configure vlan v10 ipaddress 10.10.10.1 255.255.255.0
enable ipforwarding vlan v10
configure vlan v20 ipaddress 20.20.20.1 255.255.255.0
enable ipforwarding vlan v20
# Module mcmgr configuration.
# Module fdb configuration.
# Module rtmgr configuration.
# Module policy configuration.
# Module aaa configuration.
# Module acl configuration.
# Module bfd configuration.
# Module cfgmgr configuration.
# Module dosprotect configuration.
# Module dot1ag configuration.
# Module eaps configuration.
Press <SPACE> to continue or <Q> to quit:
# Module edp configuration.
# Module elrp configuration.
# Module ems configuration.
# Module epm configuration.
# Module erps configuration.
# Module esrp configuration.
# Module ethoam configuration.
# Module etmon configuration.
# Module exsshd configuration.
# Module hal configuration.
# Module idMgr configuration.
# Module ipSecurity configuration.
# Module ipfix configuration.
# Module lldp configuration.
# Module mrp configuration.
# Module msdp configuration.
# Module netLogin configuration.
# Module netTools configuration.
# Module ntp configuration.
# Module poe configuration.
# Module rip configuration.
# Module ripng configuration.
# Module snmpMaster configuration.
# Module stp configuration.
# Module techSupport configuration.
# Module telnetd configuration.
# Module tftpd configuration.
# Module thttpd configuration.
# Module twamp configuration.
# Module vmt configuration.
# Module vsm configuration.
* X440G2-12p-10G4.24 #
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,676 Points 5k badge 2x thumb
The TTL transmit expired reply is from 116.50.128.1, is this a device in the network?
Can you check if there is some mis-configuration in the routing part?
show configuration "rtmgr" could be helpful here
Photo of David Rahn
David Rahn
  • 886 Points 500 badge 2x thumb
Good catch... i wonder now if he doesn't have the gateways set on the nics in the pc. And if he has a secind nic (wifi) on on them...
Photo of Resolut1on
Resolut1on
  • 804 Points 500 badge 2x thumb
I disabled my wireless connection now. The PC1 and PC2 not on the network now. But still PC1 cannot ping PC2, same as PC2 to PC1.
(Edited)
Photo of Paul Thornton
Paul Thornton
  • 1,424 Points 1k badge 2x thumb
Your PC looks like it doesn't have a route for 20.20.20.0/24.  And the other PC doesn't have a route for 10.10.10.0/24, even though you have it set.  I think the packets are going out to the Internet and then timing out there.
do a 'route print' on both PCs, that should show what's happening with the routing.
Paul.
Photo of Resolut1on
Resolut1on
Hi Paul,
(Edited)
Photo of Resolut1on
Resolut1on
Hi Friends,
Good day!
I give you update.
Now I can ping from both PC1 and PC2 the both gateway.
But PC1 and PC2 cannot yet ping each other.
PC1 10.10.10.10 can PING 10.10.10.1 and 20.20.20.1
PC2 20.20.20.20 can PING 20.20.20.1 and 10.10.10.1
Thanks,
Resolut1on
