Using FlexView to aggregate Client information , how to select OIDs?
  • Question
  • Updated 3 years ago
  • Doesn't Need an Answer
Dear All
I try to using FlexView to aggregate client's information (IP,  MAC, and which port he come from) on swirch
In  switch like 430 , 440  it seem no problem, and OIDs I us like:
but the same FlexView I using to show BD8806 's  client information , the port will show 6XX  5XX:
Does it need to using different OIDs to show real port on BD ? or it 's using same OIDs , but 645 means slots 6's port 45, it has slot 's mark before real port number?
the second question is   I also export this result to html and csv file .
for html  it lost  mac address 's information
for csv file it lost ReqID
Does it need to change any options 's setting for showing full information  when I export?
My Netsight 's version was 6.2.0.221.
Thank for everyone's help.
Hunt.Liao
2015/10/5 10:15 AM
Tiwan
Photo of Hunt Liao
Hunt Liao
  • 130 Points 100 badge 2x thumb
Posted 3 years ago
Photo of Bharathiraja, Suresh
Bharathiraja, Suresh, Employee
  • 3,526 Points 3k badge 2x thumb
Hi Hunt,
What all are the exos versions for X430, 440 and BD ?
Thanks,
Suresh.B
Photo of Hunt Liao
Hunt Liao
Dear  suresh
switch 's version  15.3
BD 's version       12.4
Did you mean it  different OIDs between two version  so I get  wrong show ?
Hunt.Liao
2015/10/05 12:07 PM
Taiwan
Photo of Murphy, Daniel
Murphy, Daniel, Employee
  • 632 Points 500 badge 2x thumb
Question 2:  - Export issues with FlexViews there were several bugs corrected in 6.3 related to Export showing consistently the same columns between CSV/HTML.  Are you able to upgrade?
