Verifying NAC Appliance's RADIUS Configuration for each Switch
  • Question
  • Updated 4 months ago
  • Answered
  • (Edited)
I've configured radius on the EAC and  a switch in my lab.
Also configured SNMP on both devices.
Shared secret is the same.  I dubble checked it.
When I do in Java a verify of the radius configuration, I got the error:
'unable to contcact the switch'
What is going wrong?
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,876 Points 3k badge 2x thumb
Posted 4 months ago
Photo of Yacobucci, Ryan
Yacobucci, Ryan, Multi-Tier Technical Support Engineer
  • 5,734 Points 5k badge 2x thumb
What is the switch type?
As long as it's a supported switch NAC will configure your RADIUS settings for you. Depending on switch model NAC will either use a script, or SNMP sets to configure them.
EoS has SNMP support for RADIUS configuration.
XoS needs a CLI credential for script.
Thanks
-Ryan
Johan Hendrikx
type switches: X440G2-24p-10G4 and X440G2-48p-10G4
If  XoS needs a CLI credential, is that the credential that is used when I do an 'open device terminal'?
Because this works.
(Edited)
