VX9000 and Xen
  • Question
  • Updated 7 months ago
  • Answered
Hi!!
i trying to install the iso into my Xen Lab but dont boot. Have some tips to install into XEN?
Thx.
Photo of Rodrigo Cortes
Rodrigo Cortes
  • 490 Points 250 badge 2x thumb
Posted 7 months ago
Photo of Ron Galien
Ron Galien, Employee
  • 668 Points 500 badge 2x thumb
Hello Rodrigo - We have good VX9000 Virtual Controller Installation Guide that covers this install process. Here is the link where this guide is posted:
http://documentation.extremenetworks.com/ExtremeWireless/VX9000_IG_MN001985A01A_EN.pdf
Rodrigo Cortes
Hi!
the doc dont have any info for work with Xen :(
thx
Photo of Ron Galien
Hi Rodrigo - the reference to XEN is noted on page 4 of the VX9000 Installation guide noting "Installing the VX Virtualized Controller on a Hypervisor"
Ensure a Hypervisor (ESXi, Xen, Hyper V) is installed in your server environment or the downloaded .iso
image will not run.
Here is additional information noted in this official KCS article :)
Does the VX-9000 support XenServer v7 for VM installation?
https://gtacknowledge.extremenetworks.com/articles/Q_A/Does-the-VX-9000-support-XenServer-v7-for-VM-...
Rodrigo Cortes
hi!!
I'm reading the last doc and previous doc. In the first doc dont show anything about  resource for Xen, CPU, Disk, etc... Can extrapolate from Hyper-V or VMware.
If use the option other install media, the installation is extreme slowly, even if put 4GB, 4 CPU and 10GB for disk.
Is possible try to improve the installation iso for Xen? When install showme some advance and i see info about detecting Xen, disk type xvda, etc... xentool preinstalled is better. That permit use in the VM optimization like vmotion, etc...
Thx
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 4,218 Points 4k badge 2x thumb
I have a Xen server and I have no issues installing VX9000. Yes its slower install than VMware but still not super slow. I do have my iso files in a storage repository on the Xen server. What is your vm build process?
Rodrigo Cortes
Hi Robert!
create VM using other media install, i choose 4GB for ram, 10GB disk, 4 cores 2x2 and select the media from repository and waiting to showme info about install process.
pd:reboot dont work from xencenter is necessary xentools installed.
is it possible you are out of hard drive space? Any errors in the xen logs?
