VX9000 - SNMP offline devices
  • Question
  • Updated 3 months ago
  • Answered
Is it possible to get the amount of offline devices on a VX9000 through SNMPv2 ?
Photo of Bram Assendorp
Bram Assendorp
  • 80 Points 75 badge 2x thumb
Posted 3 months ago
Photo of Andy Holden
Andy Holden, Employee
  • 1,092 Points 1k badge 2x thumb
you can use the "DEVICE OFF LINE" alert from the EVENT POLICY
Ability to track devices that are un-adopted for a specified duration of time (user configurable) and raise an event or snmp trap. This feature allows monitoring systems to subscribe to this event instead of device un-adoption. This event can be viewed under “show event-history” (or) can be forwarded to syslog or snmp manager as a trap like any other event. (no additional configuration required other than regular configuration to enable the syslog or snmp traps).
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 3,768 Points 3k badge 2x thumb
you should be able to with the below mib for 'Off line Device count '
-- 1.3.6.1.4.1.388.50.1.4.1.14.2
wingStatsNocDevOffLineInfoCount OBJECT-TYPE
SYNTAX Unsigned32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"Off line Device count
                XPath: /wing-stats/noc/device-offline-list/count"
::= { wingStatsNocDevOffLineInfo 2 }
Photo of Vedran Jurak
Vedran Jurak
  • 768 Points 500 badge 2x thumb
You can also use the following OID 1.3.6.1.4.1.388.50.1.4.1.14.2.0
Bram Assendorp
That was what I was looking for, thnx.
