What is "Frame Forwarding Rate" of X690? And where is the document?
  • Question
  • Updated 1 week ago
Photo of Athiwat Wongkhumjun
Athiwat Wongkhumjun
  • 156 Points 100 badge 2x thumb
Posted 2 weeks ago
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,962 Points 20k badge 2x thumb
Photo of Tomasz
Tomasz
  • 1,526 Points 1k badge 2x thumb
Typically the relationship between switching capacity (Gbps) and frame forwarding rate (Mpps) with 64-byte frames allows you to divide Gbps capacity by 2, multiply by 1.488 and you will get accurate Mpps most likely. This could theoretically be different because of some sophisticated switch behavior but I'm not aware of any examples.
Here it would be ~1309 Mpps.
Athiwat Wongkhumjun
Hi Tomasz,
Thank you for your reply. Any document show frame forwarding rate of X690? We need to submit document for tender. Thank you.
Photo of Tomasz
Tomasz
Hi Athiwat,
I couldn't find it so far. Perhaps it's just missing in the datasheet or there is some limitation only Extreme is aware of.
For X590 it's also not specified as well BTW. :(
(Edited)
Athiwat Wongkhumjun
Hi Tomasz,
I agreed with you! I will try to open the case.
To Extreme employee who have seen my message, please help to provide the document. Thank you.
Photo of EtherMAN
EtherMAN, Embassador
  • 7,180 Points 5k badge 2x thumb
Most of Extreme's claim to fame through the years were their switches have always been "wirespeed" when it comes to packet forwarding.  I can/t recall any time they have not met those standards and did not state the fact there was a limit of the amount of PPS the forwarding back-plane could handle.  Since everyone pretty much uses the same chip sets and there are so many things we add to just raw ethernet frames that would affect your through put it is a bit hard I would imagine to list the pps.  If i understand correctly the backplane and engine must support "theoretical " PPS by directional on all ports for all frame sizes for them to claim this.
Side note I have a link that has been a good site for me to share when folks start talking about how much or how little download upload they are getting https://null.53bits.co.uk/uploads/programming/javascript/data-calcs.html#pps-connectivity
