WLAN AP: Defining AP-Name within CLI Prompt
  • 6
  • Idea
  • Updated 1 year ago
  • Under Consideration
Because i am working for deeper troubleshooting directly on AP CLI, I am looking for a way how to see/set the AP-Name within CLI Prompt.
(Working with IdentiFi WLAN)
Here my solution (with help of my collegue):
PS1="`grep -i apname /home/config/current.cfg | cut -b 13-` # "
To make it persistant after reboot (but maybe not after update):
echo 'PS1="`grep -i apname /home/config/current.cfg | cut -b 13-` # "' >> ~/.profile
Hopefully anybody else needs this too!
Regards
Photo of M.Nees
M.Nees, Embassador
  • 9,640 Points 5k badge 2x thumb
Posted 2 years ago
  • 6
Photo of Steve Ballantyne
Steve Ballantyne
  • 5,806 Points 5k badge 2x thumb
Impressive hack!
Photo of Robert Zarzycki
Robert Zarzycki, Employee
  • 5,100 Points 5k badge 2x thumb
Mathias, what AP models does the above apply to?
Photo of M.Nees
M.Nees, Embassador
I test with an AP3715e - but i am sure this will work with all IdentiFi APs.
Steve Ballantyne
I just tested this with a 3825i and it worked just dandy.
I have created a KB article based on your findings Mathias.
Public KB Link:   Defining AP-Name within CLI Prompt
Photo of James A
James A, Embassador
  • 7,338 Points 5k badge 2x thumb
I certainly like it.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,226 Points 50k badge 2x thumb
OK so we've 42.85% of the Embassadors who support the idea :-)
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,792 Points 10k badge 2x thumb
I like the idea of showing the AP name in the prompt as well.
This can be easily implemented by Extreme in the /etc/profile file and the commands from the first post.
Overriding the system default for the prompt (which is fallback to Busybox default of unset PS1) using $HOME/.profile is appropriate for customer (or partner) implemented configuration changes on the AP.
Hi Robert,
could you add a link to this thread to the GTAC Knowledge article?
Thanks,
Erik
Eric,
      Link to the GTAC KB to this thread has been added.
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,800 Points 5k badge 2x thumb
Just to close off this thread, this feature has been added to 10.31.04 which is available for download now.
Knowledge article updated: https://gtacknowledge.extremenetworks.com/articles/How_To/Defining-AP-Name-within-CLI-Prompt
-Gareth
Photo of M.Nees
M.Nees, Embassador
Thanks a lot that this are now part of the solution and useable for all customers.
Regards,
Matthias
Steve Ballantyne
This was a great little hack Matthias. Glad to see it made it's way into the product release chain.
