AP122 turns irresponsive when upload config / upgrade firmware / reboot.
sergi_dupe
Contributor
Everytime I upload any configuration, upgrade the firmware of my AP122 or a simply reboot, the AP losses the connection with HiveManager and the status led of the AP turns orange. Then the AP keeps irresponsive and the only solution is to push the reset button of the AP or perform a 'reset config' command through CLI.
25 REPLIES 25
samantha_lynn
Esteemed Contributor III
Could you try sending it again? I'm not seeing anything yet.
sergi_dupe
Contributor
Private email sended with the ownership transfer letter.
samantha_lynn
Yes Sergi, I just sent you a response. Sorry for the delay, I wanted to get a second opinion on the data before I responded.
sergi_dupe
Contributor
Hi Sam, did you receive the last tech data log?
sergi_dupe
Contributor
Indeed, odd behaviour of the AP...
