ā04-13-2018 01:00 PM
Since the updating HiveOS on AP370s (i.e. 6.5r8a/b) to patch the KrackAttack vulnerability, our AP370s have been prone to refusing clients. As far as I could see this happens when they are under load , anecdotally 40-50 clients but no proof.
The fix tends to be to reboot, quite often I've had to fully power off.
I just upgraded half a dozen APs to 6.5r9, one of them stopped advertising and couldn't be seen in Wifi Explorer. I tried reboots, hard boot and full config restore, in the end I downgraded to 6.5r7 and it started working.
I've logged an e-mail with Aerohive support asking them to submit a bug report, thought I'd post here in case anyone else suffers similar issues.
We are toying with changing manufacturers, the AP370s have been the source of a lot of problems .
Solved! Go to Solution.
ā05-03-2018 05:44 AM
Hi Mike,
HOS 6.5r9a has just been released and itās available on the Cloud HMNG EMEA and NA instances now. The Cloud HMNG APAC/ANZA instances will be upgraded for this tonight as well. See the linked HOS 6.5r9a release notes below. Hope this helps.
http://docs.aerohive.com/330000/docs/help/english/documentation/6.5r9a_HiveOS_ReleaseNotes.pdf
Paul
ā04-26-2018 01:25 AM
Hey @Nick Loweā - you happen to have an update on this and HMNG? I have an open case that and a fix is (hopefully / supposed) to be in it.
Thanks!
ā04-19-2018 02:06 PM
What version of HM Classic are you running?
I recently upgraded my HM to 8.2r1 and noticed an issue with AP370's running 6.5r8b not allowing client connections. I then upgraded a couple 370's to 6.5r9 and it seems to have resolved my problem.
ā04-18-2018 02:25 PM
Hi Shane,
I see that your support case is now reopened.
Please work with the support engineer via that case so that your issue can be investigated.
Thanks,
Nick
ā04-18-2018 01:28 PM
Hi Mike,
HiveOS 6.5r9 is not expected to appear until the HMNG release due on-or-around the 23rd April.
Thanks,
Nick
ā04-18-2018 01:26 PM
Has this even shown up in NG for any of you yet? I know it dropped by I still show 6.5r8b as golden and 6.5r9 isn't even an option for me to manually select.
