HiveOS Matrix
HiveOS Matrix
samantha_lynn
Esteemed Contributor III
34 REPLIES 34
samantha_lynn
Hi Tran, I can help you with this if you can email me the APs serial number. My email address is communityhelp@aerohive.com.
tatekvietnam
i have ap370 and added this ap in to cloud trial,but over 30 days trial, now i want remove this ap but i can't, pls can help me? , thanks you .
samantha_lynn
You'd want to reach out to security@aerohive.com to see if we have any patches for that vulnerability.
blake
We have encountered heap overflow vulnerabilities on the current recommended firmware (10.0r7a) according to this matrix from August. Is there a newer version? I cannot access the matrix in other links either due to access errors. Is there some reason not to make this a public resource and to keep it behind lock and key?
NVT Name
CERN httpd CGI name heap overflow
Summary
It was possible to kill the remote web server by requesting GET /cgi-bin/A.AAAA[...]A HTTP/1.0 This is known to trigger a heap overflow in some servers like CERN HTTPD.
Affected Nodes
Impact
A cracker may use this flaw to disrupt your server. It *might* also be exploitable to run malicious code on the machine.
Solution
Ask your vendor for a patch or move to another server.
Vulnerability Detection Result
Vulnerability was detected according to the Vulnerability Detection Method.
Details:
(OID: 1.3.6.1.4.1.25623.1.0.17231)
Version used: 2019-04-24T07:26:10+0000
samantha_lynn
Just to add to what Ashley said, HMOL is for Classic, HM Cloud is for HiveManager (formerly NG). This guide will walk you through how to determine which HiveManager you are using, for reference: https://thehivecommunity.aerohive.com/s/article/Which-HiveManager-Platform-am-I-using
